Plex code on github
Hi I start to try a compilation of the Plex code.
I notice two major things :
  • mediastream code is not in elan/plex repository and the elan/plex-mediastream seems to have not be updated since the last release. Is it possible to correct this by adding mediastream in the skin folder of elan/plex or by updating elan/plex-mediastream ?
  • It seems there is lot of files in elan/plex repository which is not used (like skin Project Mayhem III). Is it plan to make some clean ? This will make it easier for new dev like me to dicover the Plex code.
That's because (as far as I know) there haven't been any MediaStream changes since the last release :) If you notice any discrepancies please point me towards them.
These are left in to keep our repo as close to the XBMC repo as possible. It may not appear "clean" but it really helps when merging changes between the two projects.
OK first I've looked in the master branch. In there there are plenty of differences but no activity :D
In the chimera branch (which seems to be the active one), I notice few differences. See diff file in attachment
If you make an update take my french string file (on [the forum](http://forums.plexapp.com/index.php?showtopic=7273), in[lighthouse](https://plexapp.lighthouseapp.com/projects/15067/tickets/314-update-french-localization) or in the pull request in [github](http://github.com/oncleben31/plex-mediastream/commit/ce288e7a570f69c4e51d3f62ed18a2ff90478620))
Best way I admit :P
