Apple TV: ATV3 V7.2.2
Apple TV DNS: 192.168.2.40
Local IP: 192.168.2.40
PlexConnect and Plex Media Server both installed on Mac Mini running MacOS Sierra V10.12
Plex Media Server Version: 1.3.3.3148
PlexConnect downloaded from GitHub today (January 10, 2017)
I have installed plexConnect and Plex Media Server on a new Mac Mini. I am able to connect to PlexConnect through the trailers App on my apple tv, however there is no media available. Under my Library tab on the apple tv it says “PlexConnect - No Plex Library Sections Available”. After looking through the logs a bit I see where it says
“PlexAPI: No Response from Plex Media Server”
“PlexAPI: We failed to reach a server. Reason: Unauthorized”
This is really my only clue as to what is going on. Any help would be greatly appreciated.
23:11:25 PlexConnect: ***
23:11:25 PlexConnect: PlexConnect
23:11:25 PlexConnect: Press CTRL-C to shut down.
23:11:25 PlexConnect: started: 23:11:25
23:11:25 PlexConnect: Version: 0.5-dev-110616
23:11:25 PlexConnect: Python: 2.7.10 (default, Jul 30 2016, 18:31:42)
[GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
23:11:25 PlexConnect: Host OS: darwin
23:11:25 PlexConnect: PILBackgrounds: Is PIL installed? False
23:11:25 PlexConnect: IP_self: 192.168.2.40
23:11:25 DNSServer: started: 23:11:25
23:11:25 DNSServer: ***
23:11:25 DNSServer: DNSServer: Serving DNS on 192.168.2.40 port 53.
23:11:25 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.2.40
23:11:25 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
23:11:25 DNSServer: forward other to higher level DNS: 8.8.8.8
23:11:25 WebServer: started: 23:11:25
23:11:25 WebServer: ***
23:11:25 WebServer: WebServer: Serving HTTP on 192.168.2.40 port 80.
23:11:26 WebServer: ***
23:11:26 WebServer: WebServer: Serving HTTPS on 192.168.2.40 port 443.
23:11:32 DNSServer: DNS request received!
23:11:32 DNSServer: Source: (‘192.168.2.25’, 56091)
23:11:32 DNSServer: Domain: p55-buy.itunes.apple.com
23:11:32 DNSServer: ***forward request
23:11:32 DNSServer: -> DNS response from higher level
23:11:34 DNSServer: DNS request received!
23:11:34 DNSServer: Source: (‘192.168.2.25’, 63723)
23:11:34 DNSServer: Domain: se.itunes.apple.com
23:11:34 DNSServer: ***forward request
23:11:35 DNSServer: -> DNS response from higher level
23:11:35 DNSServer: DNS request received!
23:11:35 DNSServer: Source: (‘192.168.2.25’, 56510)
23:11:35 DNSServer: Domain: trailers.apple.com
23:11:35 DNSServer: ***intercept request
23:11:35 DNSServer: -> DNS response: 192.168.2.40
23:11:35 WebServer: serving /js/application.js
23:11:35 WebServer: serving .xml: /
23:11:35 PlexAPI: ***
23:11:35 PlexAPI: PlexGDM - looking up Plex Media Server
23:11:36 PlexAPI: GDM: Servers discovered: 1
23:11:36 PlexAPI: Servers (local, plex.tv, MyPlex): 2
23:11:37 WebServer: serving .xml: /PlexConnect.xml
23:11:37 WebServer: serving /js/utils.js
23:11:37 WebServer: serving /js/handlePlexConnectNavbar.js
23:11:37 WebServer: serving .xml: /library/sections
23:11:37 PlexAPI: No Response from Plex Media Server
23:11:37 PlexAPI: We failed to reach a server. Reason: Unauthorized
23:11:38 PlexAPI: Traceback:
Traceback (most recent call last):
File “/Applications/PlexConnect-master/PlexAPI.py”, line 432, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 154, in urlopen
return opener.open(url, data, timeout)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 437, in open
response = meth(req, response)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 550, in http_response
‘http’, request, response, code, msg, hdrs)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 475, in error
return self._call_chain(*args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 409, in _call_chain
result = func(*args)
File “/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 558, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
23:11:38 WebServer: serving /js/utils.js
23:11:38 WebServer: serving /js/sectionHoldSelect.js
23:20:17 DNSServer: DNS request received!
23:20:17 DNSServer: Source: (‘192.168.2.25’, 61832)
23:20:17 DNSServer: Domain: init.itunes.apple.com
23:20:17 DNSServer: ***forward request
23:20:18 DNSServer: -> DNS response from higher level
23:20:18 DNSServer: DNS request received!
23:20:18 DNSServer: Source: (‘192.168.2.25’, 64688)
23:20:18 DNSServer: Domain: xp.apple.com
23:20:18 DNSServer: ***forward request
23:20:19 DNSServer: -> DNS response from higher level
23:20:19 DNSServer: DNS request received!
23:20:19 DNSServer: Source: (‘192.168.2.25’, 55041)
23:20:19 DNSServer: Domain: apps.itunes.com
23:20:19 DNSServer: ***forward request
