Server Version#: 1.20.1.3252
Player Version#: 4.34.4
In local i can see and play to plex web, the remote access is green.
But in app plex no access to my file
Then make sure user plex has access permission.
Docker enforces the underlying Linux host permissions.
Just because you can see it doesn’t mean user plex can.
Check the PUID and PGID -or- file permission masks.
Hello,
This is the docker plex file:
sudo docker run
-d
–name DSplexInside
–network=host
-e CHANGE_CONFIG_DIR_OWNERSHIP=true
-e PLEX_GID=0
-e PLEX_UID=0
-e TZ=Europe/Paris
-p 32400:32400
-p 1900:1900/tcp
-p 32469:32469/tcp
-h DSplexInside
-v /volume1/docker/plex/database:/config:rw
-v /volume1/docker/plex/temp:/transcode:rw
-v /volume1/docker/plex/crt:/data/certificat:rw
-v /volume2/tvshows:/data/tvshows:rw
-v /volume2/musics:/data/musics:rw
-v /volume2/movies:/data/movies:rw
-v /volume2/audiobooks:/data/audiobooks:rw
-v /volume2/book:/data/books:rw
–restart always
plexinc/pms-docker:latest
I just noticed something.
You’re running this on a Synology host?
If so, which model?
yes, it always work without issue.
model: DS3615xs
7 SSD
4 HDD
i7
32gb
XPEnology? Figures
DSM 6 or DSM 5 ?
DSM 6’s latest doesn’t allow direct use of max_user_watches in /etc/sysctl.conf.
They ignore then overwrite it independent of what is stated.
This is the perpetual cat & mouse game with them.
The proper way to do this (which changes again in DSM 7) is
For the first part i have this result:
audiobooks 7
book 62
movies 6858
musics 1597
tvshows 812
=9336
+32768
42104
/32768
1.28
1+1
2
*32768
= 65536
For the only docker folder, 18 container, i have this:
docker 559747
+32768
592515
/32768
18
18+1
19
*32768
= 622592
That’s the correct value (65536) to enter for s2s_watches_max
Dear user,
Task Scheduler has completed a scheduled task.
Task: increases 2s_watches_max linux table
Start time: Sun, 04 Oct 2020 19:40:02 GMT
Stop time: Sun, 04 Oct 2020 19:40:02 GMT
Current status: 0 (Normal)
Standard output/error:
From Z-SERVER
Are you putting media inside the Plex container (/config) ??
From what was posted above, the only areas to concern with are:
Obtain that composite total
No,
yes, i did it, the result is correct (65536)
Thanks for helping me, for your time, for everything !!!
Sorry that I’m being pulled all over the place today.
Is everything working now?
yes everything works.
But can you explain what’s happen about the remote access?
There is something happening at Plex.tv, between it and PMS , which is a fallout of the outage.
Resetting the certificate was the first step. It was thought to be the only required step.
I’m seeing other indications to the contrary which I’ve forward to both the Plex.tv and server teams to review. When they are in the office tomorrow (Monday) I’m sure they will contact me for more info if needed.
