The crash reports are failing to get uploaded
Whilst the server is able to communicate with plex.tv, all attempts to communicate with https://crashreport.plexapp.com are failing
Have you by any chance blocked access to this domain?
I have had the system checked out and it was operational throughout the periods when your server failed to get to it to upload crash reports
Feb 26, 2018 17:11:01.554 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:11:01.554 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 26, 2018 17:11:01.557 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:11:01.557 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 26, 2018 17:45:59.732 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:45:59.732 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 26, 2018 17:45:59.734 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:45:59.734 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 26, 2018 17:45:59.736 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:45:59.736 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 26, 2018 17:48:06.580 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:48:06.580 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 26, 2018 17:48:06.583 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:48:06.583 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 26, 2018 17:48:06.586 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 26, 2018 17:48:06.586 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 28, 2018 19:33:37.655 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Feb 28, 2018 19:33:37.971 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 28, 2018 19:33:37.971 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 28, 2018 19:33:37.972 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Feb 28, 2018 19:33:37.973 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 28, 2018 19:33:37.973 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Feb 28, 2018 19:33:37.974 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Feb 28, 2018 19:33:37.975 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Feb 28, 2018 19:33:37.975 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 18:26:47.471 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Mar 01, 2018 18:26:47.499 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 18:26:47.499 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 18:26:47.500 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Mar 01, 2018 18:26:47.502 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 18:26:47.502 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 18:26:47.503 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Mar 01, 2018 18:26:47.505 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 18:26:47.505 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 18:26:47.506 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.ple xapp.com
Mar 01, 2018 18:26:47.508 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 18:26:47.508 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 20:21:31.478 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Mar 01, 2018 20:21:31.504 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 20:21:31.504 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 20:21:31.505 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Mar 01, 2018 20:21:31.506 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 20:21:31.506 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 20:21:31.507 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Mar 01, 2018 20:21:31.508 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 20:21:31.508 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Mar 01, 2018 20:21:31.509 [0x7fff77080000] DEBUG - HTTP requesting POST https://crashreport.plexapp.com
Mar 01, 2018 20:21:31.511 [0x7fff77080000] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 01, 2018 20:21:31.511 [0x7fff77080000] WARN - HTTP error requesting POST https://crashreport.plexapp.com (0, No error) (Failed to connect to 184.105.148.89: Host is down)
Curl error 7 is
CURLE_COULDNT_CONNECT (7) - Failed to connect() to host or proxy.
The host was not down and there were uploads from other servers. So I suspect an issue at your end and your firewall / network
I have no dumps to get looked at
The only info I have is this error message logged before crashing
Mar 01, 2018 18:26:47.114 [0x70000073b000] ERROR - Exception getting remote address: remote_endpoint: Invalid argument
This error is the same as seen in another user’s log on this forum topic
which was followed by a crash to due with some exception when dealing with an SSL Connection
May be this SSL issue is also why the connection to crashreport.plexapp.com is failing
Have you installed some SSL software ?
Are you using a VPN ?
I do see some extra network interfaces in addition to the local subnet
Mar 01, 2018 20:21:32.434 [0x70000052f000] DEBUG - Network interfaces:
Mar 01, 2018 20:21:32.434 [0x70000052f000] DEBUG - * 4 en0 (192.168.2.27) (loopback: 0)
Mar 01, 2018 20:21:32.434 [0x70000052f000] DEBUG - * 11 vnic0 (10.211.55.2) (loopback: 0)
Mar 01, 2018 20:21:32.434 [0x70000052f000] DEBUG - * 12 vnic1 (10.37.129.2) (loopback: 0)
With regards to the connection SSL crash that the other user had and may well be the same crash for your server, a fix is being produced to stop the crash
