Plex crashes on second stream
Server Version#: 1.25.7.5604
Player Version#: WEB Version 4.76.1
Tuner Make/Model: Xteve
Using XMLTV?: yes
Channel number/Name: all
Hello everyone,
I use xteve together with plex. I have limited xteve to 1 stream. Use ffmpeg as a buffer.
All works fine but when I start a second stream in plex, my whole plex hangs for around 5 min.
It’s only when I start 2 different streams in Plex, 2 times the same stream works fine.
When I play a stream in VLC and start a second in Plex, it shows “xteve no stream available”. As expected.
Can somebody help me troubleshoot this?
Here are the logs: error crash happened on 19:23,10
Plex Media Server logs.zip (118.3 KB)
