Plex Crashes
I recently bought a new synology rackstation.
I installed plex. However, it often crashed and the service stopped sporadically on the synology.
I have attached the logs.
Please help me.
Thank you for the logs,
PMS is complaing of LPE (Local Path Evaluator) errors. This means it’s trying to find media which isn’t there.
The first thing I suggest you do the following;
  1. Scan Library Files
  2. Empty Trash
  3. Clean Bundles
  4. Restart PMS
  5. See what is missing from your library.
Sep 07, 2017 03:58:04.769 [0x7fb50230b700] DEBUG - BPQ: generating queue items from 6 generator(s)
Sep 07, 2017 03:58:04.770 [0x7fb50230b700] ERROR - LPE: unknown item 7294.
Sep 07, 2017 03:58:04.770 [0x7fb50230b700] ERROR - Sync: failed to generate query for path library://b12bb7bb-4619-48cf-8e11-9f559c2c1912/item/%2Flibrary%2Fmetadata%2F7294 in sync item 18473459
Sep 07, 2017 03:58:04.770 [0x7fb50230b700] ERROR - Sync: skipping items for sync list 14193904, sync item 18473459: unable to generate sync set query
Sep 07, 2017 03:58:04.771 [0x7fb50230b700] ERROR - LPE: unknown item 7312.
Sep 07, 2017 03:58:04.771 [0x7fb50230b700] ERROR - Sync: failed to generate query for path library://b12bb7bb-4619-48cf-8e11-9f559c2c1912/item/%2Flibrary%2Fmetadata%2F7312 in sync item 18473463
Sep 07, 2017 03:58:04.771 [0x7fb50230b700] ERROR - Sync: skipping items for sync list 14193904, sync item 18473463: unable to generate sync set query
Sep 07, 2017 03:58:04.772 [0x7fb50230b700] ERROR - LPE: unknown item 7333.
Sep 07, 2017 03:58:04.772 [0x7fb50230b700] ERROR - Sync: failed to generate query for path library://b12bb7bb-4619-48cf-8e11-9f559c2c1912/item/%2Flibrary%2Fmetadata%2F7333 in sync item 18473464
Sep 07, 2017 03:58:04.772 [0x7fb50230b700] ERROR - Sync: skipping items for sync list 14193904, sync item 18473464: unable to generate sync set query
Sep 07, 2017 03:58:04.772 [0x7fb50230b700] ERROR - LPE: unknown item 7328.
Sep 07, 2017 03:58:04.773 [0x7fb50230b700] ERROR - Sync: failed to generate query for path library://b12bb7bb-4619-48cf-8e11-9f559c2c1912/item/%2Flibrary%2Fmetadata%2F7328 in sync item 18473465
Sep 07, 2017 03:58:04.773 [0x7fb50230b700] ERROR - Sync: skipping items for sync list 14193904, sync item 18473465: unable to generate sync set query
Sep 07, 2017 03:58:04.775 [0x7fb50230b700] DEBUG - Sync: updating status for sync list 14193904, sync item 19460122, generator 2251
Sep 07, 2017 03:58:04.778 [0x7fb50230b700] ERROR - LPE: unknown item 7370.
Sep 07, 2017 03:58:04.778 [0x7fb50230b700] ERROR - Sync: failed to generate query for path library://b12bb7bb-4619-48cf-8e11-9f559c2c1912/item/%2Flibrary%2Fmetadata%2F7370 in sync item 19895342
Sep 07, 2017 03:58:04.779 [0x7fb50230b700] ERROR - Sync: skipping items for sync list 14193904, sync item 19895342: unable to generate sync set query
Sep 07, 2017 03:58:04.779 [0x7fb50230b700] DEBUG - BPQ: generated 0 item(s) for queue
Sep 07, 2017 03:58:04.779 [0x7fb50230b700] DEBUG - PlayQueue: 0 generated IDs compressed down to a 2 byte blob.
Sep 07, 2017 03:58:04.831 [0x7fb50230b700] DEBUG - BPQ: [Processing] -> [Idle]
Sep 07, 2017 03:58:04.831 [0x7fb50230b700] DEBUG - BPQ: garbageCollect - sync - forced - 1
Sep 07, 2017 03:58:04.831 [0x7fb50230b700] DEBUG - Sync: starting Sync garbage collection: 1, forced
I will try accordingly. Thank you.
