Plex Crashing Immediately after update
Server Version#: v1.40.0.7998
Hi Everyone,
Trying to update my plex server, i have a spare machine that doesnt have a GPU, thats been running my server for a while on Version 1.40.0.7998
Whenever i try to update, Plex refuses to launch
Logs Are below
Jan 09, 2025 00:47:15.155 [11456] INFO - Plex Media Server v1.40.5.8921-836b34c27 - Microsoft PC x64-x64 - build: windows-x86_64 windows - GMT 11:00
Jan 09, 2025 00:47:15.155 [11456] INFO - Windows version: 10.0 (Build 22631), language en-US
Jan 09, 2025 00:47:15.155 [11456] INFO - 6 3593 MHz processor(s): Architecture=9, Level=23, Revision=28928 Processor Identifier=AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD
Jan 09, 2025 00:47:15.155 [11456] INFO - Compiler is - MSVC 1929
Jan 09, 2025 00:47:15.155 [11456] DEBUG - “C:\Program Files\Plex\Plex Media Server\Plex Media Server.exe”
Jan 09, 2025 00:47:15.156 [11432] DEBUG - Plex for Windows Store application is not installed
Jan 09, 2025 00:47:15.156 [11432] DEBUG - BPQ: [Idle] → [Starting]
Jan 09, 2025 00:47:15.157 [11432] DEBUG - FeatureManager: Using cached data for features list
Jan 09, 2025 00:47:15.159 [11432] DEBUG - MyPlex: mapping state set to ‘Unknown’.
Jan 09, 2025 00:47:15.160 [11432] DEBUG - Relay: read 5 cached entries from hosts file
Jan 09, 2025 00:47:15.160 [11432] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Jan 09, 2025 00:47:15.168 [11432] INFO - SQLITE3:0x7ff71117a1a0, 283, recovered 160 frames from WAL file C:\Users\Server\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db-wal
Jan 09, 2025 00:47:15.199 [11432] DEBUG - MyPlex: using cached data for request for https://plex.tv/api/v2/server/users/features
Jan 09, 2025 00:47:15.363 [11432] DEBUG - [CERT] Subject name is /CN=*.d30e08b6ec5c49d1a01bde8ab6096e65.plex.direct
Jan 09, 2025 00:47:15.363 [11432] DEBUG - [CERT] Installed certificate with fingerprint e1:b8:4d:ec:1d:a8:3c:d1:57:f3:2d:26:a1:68:9b:34:03:1d:f1:d3.
Jan 09, 2025 00:47:15.363 [11432] DEBUG - [CERT/OCSP] Stapling requests will be made to ‘http://r11.o.lencr.org/’.
Jan 09, 2025 00:47:15.363 [11432] INFO - [CERT/OCSP] Successfully retrieved response from cache.
Jan 09, 2025 00:47:15.364 [11432] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Jan 09, 2025 00:47:15.364 [11432] DEBUG - HttpServer: Listening on port 32400.
Jan 09, 2025 00:47:15.364 [11432] DEBUG - HttpServer: Listening on port 32401.
Jan 09, 2025 00:47:15.364 [11432] DEBUG - Running server…
Jan 09, 2025 00:47:15.364 [11492] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Jan 09, 2025 00:47:15.364 [11432] INFO - Running migrations. (EPG 0)
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 0.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 1.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 2.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 3.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 4.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 5.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 6.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 7.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 8.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 9.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 10.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 11.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 12.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 13.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 14.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 15.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 16.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 17.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 18.
Jan 09, 2025 00:47:15.365 [11432] DEBUG - Captured session 19.
Jan 09, 2025 00:47:15.370 [11432] DEBUG - ChangestampAllocator: initialized to 207429
Jan 09, 2025 00:47:15.372 [11432] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.39.4, threadsafe=1
Jan 09, 2025 00:47:15.379 [11432] INFO - SQLITE3:0x7ff71117a1a0, 283, recovered 31 frames from WAL file C:\Users\Server\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.blobs.db-wal
Jan 09, 2025 00:47:15.381 [11432] INFO - Running migrations. (EPG 0)
Jan 09, 2025 00:47:15.382 [11432] DEBUG - Captured session 0.
Jan 09, 2025 00:47:15.382 [11432] DEBUG - Captured session 1.
Jan 09, 2025 00:47:15.387 [11476] DEBUG - [GPU] Got device: Microsoft Basic Render Driver, unknown@unknown, default false, best true, ID 1414:008c, DevID [1414:008c], flags 0x0
Jan 09, 2025 00:47:15.387 [11476] DEBUG - [GPU] Got device: Microsoft Basic Render Driver, unknown@unknown, default false, best false, I
Im not exactly sure, but it might be complaining about the driver here, hoping someone can help.
Why are you trying to install such an old version?
Here’s what you should try:
  • verify there is plenty of free space on drive C:
  • shut down plex using its task tray icon
  • try and repair the plex database, using this .bat file: PlexDBRepair/Windows at master · ChuckPa/PlexDBRepair · GitHub
  • download the latest Plex Media Server installer for Windows manually and install it. Download links are below. DON’T install in any other place than the default C:\Program Files\Plex\Plex Media Server
Might of explained poorly, I’m trying to install the latest version already.
Running into the same issue after running the above batch file
Jan 09, 2025 01:20:26.959 [12484] INFO - Plex Media Server v1.41.3.9314-a0bfb8370 - Gigabyte Technology Co., Ltd. B450M H x64-x64 - build: windows-x86_64 windows - GMT 11:00
Jan 09, 2025 01:20:26.959 [12484] INFO - Windows version: 10.0 (Build 22631), language en-US
Jan 09, 2025 01:20:26.959 [12484] INFO - 6 3593 MHz processor(s): Architecture=9, Level=23, Revision=28928 Processor Identifier=AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD
Jan 09, 2025 01:20:26.959 [12484] INFO - Compiler is - MSVC 1929
Jan 09, 2025 01:20:26.959 [12484] DEBUG - “C:\Program Files\Plex\Plex Media Server\Plex Media Server.exe”
Jan 09, 2025 01:20:26.965 [13204] DEBUG - Plex for Windows Store application is not installed
Jan 09, 2025 01:20:26.966 [13204] DEBUG - BPQ: [Idle] → [Starting]
Jan 09, 2025 01:20:26.967 [13204] DEBUG - MyPlex: mapping state set to ‘Unknown’.
Jan 09, 2025 01:20:26.967 [13204] DEBUG - Relay: read 0 cached entries from hosts file
Jan 09, 2025 01:20:26.967 [13204] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Jan 09, 2025 01:20:27.002 [13204] DEBUG - MyPlex: no cached data to load for request for https://plex.tv/api/v2/server/users/features
Jan 09, 2025 01:20:27.190 [13204] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Jan 09, 2025 01:20:27.190 [13204] DEBUG - HttpServer: Listening on port 32400.
Jan 09, 2025 01:20:27.191 [13204] DEBUG - HttpServer: Listening on port 32401.
Jan 09, 2025 01:20:27.191 [13204] DEBUG - Running server…
Jan 09, 2025 01:20:27.191 [1776] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Jan 09, 2025 01:20:27.191 [13204] INFO - Running migrations. (EPG 0)
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 0.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 1.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 2.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 3.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 4.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 5.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 6.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 7.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 8.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 9.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 10.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 11.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 12.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 13.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 14.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 15.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 16.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 17.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 18.
Jan 09, 2025 01:20:27.192 [13204] DEBUG - Captured session 19.
Jan 09, 2025 01:20:27.194 [13204] DEBUG - ChangestampAllocator: initialized to 0
Jan 09, 2025 01:20:27.194 [13204] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.39.4, threadsafe=1
Jan 09, 2025 01:20:27.207 [13204] INFO - Running migrations. (EPG 0)
Jan 09, 2025 01:20:27.207 [13204] DEBUG - Captured session 0.
Jan 09, 2025 01:20:27.207 [13204] DEBUG - Captured session 1.
Jan 09, 2025 01:20:27.212 [6712] DEBUG - [GPU] Got device: Microsoft Basic Render Driver, unknown@unknown, default false, best true, ID 1414:008c, DevID [1414:008c], flags 0x0
Jan 09, 2025 01:20:27.212 [6712] DEBUG - [GPU] Got device: Microsoft Basic Render Driver, unknown@unknown, default false, best false, ID 1414:008c#2, DevID [1414:008c], flags 0x0
Ran the update again same issue.
C drive has 55GB of free space and i havent changed the location of the installation, its been in default.
Have you performed the database repair?
Did you buy Plex Pass only recently?
i ran the .bat file and goes through pretty quick and then closes
Doesnt seem to change the error message at all
Jan 09, 2025 01:27:46.538 [1532] INFO - Plex Media Server v1.41.3.9314-a0bfb8370 - Gigabyte Technology Co., Ltd. B450M H x64-x64 - build: windows-x86_64 windows - GMT 11:00
Jan 09, 2025 01:27:46.538 [1532] INFO - Windows version: 10.0 (Build 22631), language en-US
Jan 09, 2025 01:27:46.538 [1532] INFO - 6 3593 MHz processor(s): Architecture=9, Level=23, Revision=28928 Processor Identifier=AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD
Jan 09, 2025 01:27:46.538 [1532] INFO - Compiler is - MSVC 1929
Jan 09, 2025 01:27:46.538 [1532] DEBUG - “C:\Program Files\Plex\Plex Media Server\Plex Media Server.exe”
Jan 09, 2025 01:27:46.541 [2528] DEBUG - Plex for Windows Store application is not installed
Jan 09, 2025 01:27:46.541 [2528] DEBUG - BPQ: [Idle] → [Starting]
Jan 09, 2025 01:27:46.543 [2528] DEBUG - MyPlex: mapping state set to ‘Unknown’.
Jan 09, 2025 01:27:46.543 [2528] DEBUG - Relay: read 0 cached entries from hosts file
Jan 09, 2025 01:27:46.543 [2528] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.39.4, threadsafe=1
Jan 09, 2025 01:27:46.583 [2528] DEBUG - MyPlex: no cached data to load for request for https://plex.tv/api/v2/server/users/features
Jan 09, 2025 01:27:46.765 [2528] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Jan 09, 2025 01:27:46.765 [2528] DEBUG - HttpServer: Listening on port 32400.
Jan 09, 2025 01:27:46.766 [2528] DEBUG - HttpServer: Listening on port 32401.
Jan 09, 2025 01:27:46.766 [2528] DEBUG - Running server…
Jan 09, 2025 01:27:46.766 [2800] DEBUG - HttpServer: Set up a thread pool with 2 threads.
Jan 09, 2025 01:27:46.766 [2528] INFO - Running migrations. (EPG 0)
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 0.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 1.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 2.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 3.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 4.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 5.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 6.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 7.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 8.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 9.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 10.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 11.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 12.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 13.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 14.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 15.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 16.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 17.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 18.
Jan 09, 2025 01:27:46.767 [2528] DEBUG - Captured session 19.
Jan 09, 2025 01:27:46.769 [2528] DEBUG - ChangestampAllocator: initialized to 0
Jan 09, 2025 01:27:46.769 [2528] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.39.4, threadsafe=1
Jan 09, 2025 01:27:46.776 [2528] INFO - Running migrations. (EPG 0)
Jan 09, 2025 01:27:46.777 [2528] DEBUG - Captured session 0.
Jan 09, 2025 01:27:46.777 [2528] DEBUG - Captured session 1.
Jan 09, 2025 01:27:46.782 [6996] DEBUG - [GPU] Got device: Microsoft Basic Render Driver, unknown@unknown, default false, best true, ID 1414:008c, DevID [1414:008c], flags 0x0
Jan 09, 2025 01:27:46.782 [6996] DEBUG - [GPU] Got device: Microsoft Basic Render Driver, unknown@unknown, default false, best false, ID 1414:008c#2, DevID [1414:008c], flags 0x0
No plex pass was purchased a while back.
Does this board have any sort of monitor connector?
If it does, which type of graphics adapter is on/in it?
And if there is a GPU, is the proper driver software installed?
I found it!!!
The PC had a Nvidia GPU that was previously connected thats now been removed.
I went through and uninstalled the GPU and now it seems to be working fine!
