I have been trying to cast from my Galaxy S20 and when i choose the device i want to cast to it just keeps playing on the phone then eventually crashes about 30 seconds later. I’ve had this issue for a couple of weeks. I decided to try to cast from my Huawei media pad and the exact same issue. I can cast to the same device from my Ipad with no issues. The 2 android devices are fine to cast other apps however, this is only a problem when casting plex.
I’m unsure if the problem is the same but I have a similar problem when trying to cast to Chromecast.
I tried with both a Samsung Galaxy S20 and Samsung A70, and both just don’t want to cast to it. It plays no problem on the device itself.
Note that the actual casting works, the issue lies with it actually playing the media.
I also tried removing and installing the apps, restarted my media server but no luck.
What’s odd is that when looking at my dashboard it shows as playing and counts to like 20 seconds and then goes to 0 again. Whilst no playback is actually happening.
Those are exactly the symptoms we’re seeing. What version of Android are on those devices? I don’t think it has anything to do with the media server or chromecast. This seems to have manifested itself after the latest Android update. As I posted above, using a tablet with an earlier version of Android works just fine.
Yes, that adds tremendous value and quite helpful. So it appears that earlier versions of Android are not exhibiting this problem. Perhaps this is a Chromecast/Boomerang app problem. I know I used to be able to use the S20 but haven’t been able to since the last update. So perhaps some new security behavior or setting is getting in the way.
You’re absolutely right. A clear cause seems hard to determine.
Something should be done with either the Plex app or Chromecast to fix this. This isn’t an isolated incident. Granted, there are few here commenting on it. But that’s a small percentage of those effected (affected? I’m never quite sure). Here’s hoping that our concerns are drawing some attention.
