Plex crashing. Sometimes every 5 minutes
Server Version#: 1.30.0.6486
Player Version#: 4.97.3
Plex Media Server Logs_2022-12-22_15-24-07.zip (1.5 MB)
Can only suggest trying these links:
https://support.plex.tv/articles/206910047-windows-repeated-crashes-of-plex-media-server/
https://support.plex.tv/articles/201455336-crash-logs-plex-media-server/
Not sure if you can examine the dump yourself?..
Try disabling hardware acceleration in settings > Transcoding. That fixed it for me. Apparently a recent update broke hardware acceleration. Either keep it disabled or rollback. Theres also been talk of disabling “loudness” in a setting somewhere that is also causing crashing for some. Try these one at a time and report back if one of them fixed the issue.
The logs do not show crashes but in each case a database optimization that is taking a long time to run
It is possible that if you leave the server to run that the database optimization does complete eventually - How big are the database files ? Sometimes optimizations may take over 20 minutes to complete
The database files on your system are
C:\Users\Administrator\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db
C:\Users\Administrator\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db-wal
C:\Users\Administrator\AppData\Local\Plex Media Server\Plug-in Support\Databases\com.plexapp.plugins.library.db-shm
It is possible there were some crashes if other threads were held up too long whilst the optimization was running and getting an exception - this specific issue was addressed in the latest beta version 1.30.1
  • (Database) Server might quit unexpectedly after SQLite3 syntax errors (#13942)
So suggest running with 1.30.1 and run a database optimize manually and wait until it completes
Troubleshooting | Plex Support
I actually figured it out and feel kind of like an idiot. I actually had a script running in Tautulli that would restart the server if it detected Plex wasn’t running. For some reason it was just randomly restarting Plex even when it was running fine. Sorry it took so long to respond.
