If i try to install plex dash on Android it says
This app isn’t available for your device because it was made for an older version of Android
Would it be possible to mark the application as compatible with 14?
We have an updated version of the app coming out, I’m not sure current version wouldn’t be compatible, it’s the first I’ve seen.
I am seeing the same thing in the Play Store. Current software version is 13. Someone I know has it on Android 13, but it was migrated from old phone.
Is it possible that there is a setting that needs to be added to the package on the Play Store? It acts like a download limitation VS a runtime limitation. Play Store won’t let the app download.
This is related to a policy change in Android 14. See here under the heading Blocking old app installs:
If you had Dash installed prior to updating to Android 14, it will continue working, but new installs are currently blocked.
We’re in the process of finalising an update to Dash that will resolve this. Apologies for the inconvenience!
The updated build is available now and Dash should be installable on Android 14. See here for the release notes:
