Plex deleting tv show folders
Server Version#: latest
So I’m running PMS on a synology server, everything is latest version fwiw.
I’m using cloud sync in conjunction with WebDAV so my server can auto duplicate certain tv series into my archive folders. This works great btw. The small issue I have is when I’m done with the tv show and delete it from the plex library, it’s deleting the entire folder and created an error in cloud sync saying the folder no longer exists. I also have sonarr running, and even though it re creates the folder, the error doesn’t go away. I’ve been messing around with permissions on the folders in question hoping to block the user plex from being able to delete the folder but so far no go. Anyone with a suggestion would be super helpful. Thanks
Put in a blank text file in there. PMS will remove the folder if there are no files left. By having 1 in there, this won’t happen.
Thanks, will try this
