Plex dev please help
Before I go purchase a second gpu can a dev please answer me?
My server is on windows 10 pro with a nvidia 1650 gpu.
i was unaware of the 2 transcode limit when I purchased the card.
I have tried the patch and it did not work for me.
If I add a second nvidia card will I have an additional 2 hardware transcodes?
Thank you
No, from my understanding it will only use the GPU that windows is using as the primary, so you’d still be stuck with just 2 transcodes and a card doing nothing.
ok thank you, i also have a rx570 8gig card, is amd supported under windows 10 and will the amount of hardware transcodes be limited?
