I installed the latest version of plex and other problems came up. … I can no longer view the media via dlna from my TV and even listen to the main songs of the films … needless to say that before the update everything was working as it should !!! I’m having more problems than good after the updates on the server … how is that possible !?
THIS DID NOT HAPPEN BEFORE THE SERVER UPDATE !!
I’m quite sure it was never possible to stream extras like related music of a film, trailers etc. through DLNA. You can see those when accessing your library in a Plex client app.
If you’re actually using a Plex app – would you mind sharing some basic information like what actual app/platform the TV is running (and what version), and what version of PMS you have installed?
Server: 1.28.2.6151
Client: 5.47.1
Smart tv Samsung
Yes I know, I meant from the app … from the app on the tidal smart tv doesn’t work
Are the Tidal hubs missing completely or do you get some error message when attempting to play a song/track?
Does it work for you if you’re accessing the same content from a different player (e.g. Plex Web)?
tidal on the smart tv reports a “… not playable” error.
And no … these problems happen only from TV. If I try from my smartphone or browser, everything works fine.
Again, these problems (including DLNA) appeared after the last update on the server!
As for tidal, the error is: “Could not find server to create playable!”
As for the DLNA it is that all the icons/thumbnails of the films have disappeared and it does not even reproduce them …
