Just transferred my tidal hifi account to plex. Now tidal is not working in plex anymore.
My account says i have Plex premium + Tidal. But my server says they are not linked
What to do?
What to do?
iād suggest
first, go @ https://plex.tv/users/other-services sign out of tidal, and then relink your tidal account.
then second, restart your plex server.
Thanks for the quick reply! Worked like a charm/problem solved.
Found another problem now. Tidal works directly on my server, but not on any clients (android/ps4)
probably client caching, did you try restarting the devices?
it is, or is not, working on @ Plex Web ?
Web working. Restarted PS4, and restarted+clear chache on android. No change
What part is not working? You donāt see the Tidal content, or you see it, but they donāt play?
āNo content availible for this libraryā.
Hard to check PS4 but if you can provide the log from the Android app, I can check that.
Log attached
plex-log-Shamanix84.zip (792.2 KB)
I got every problem i had fixed eventualy. Android app just started working suddenly (no manual change), and PS4 app worked after reinstalling app and linking it to plex account again. Thanks for the fast replies guys.
