Plex docker crashes from massive flood of errors
Server Version#: 1.15.0.647-2-01 and newer on unRAID
Player Version#: all
getting hammered with this using the integrated clearsync gpu of the i7 6700K
after a day or so it locks up the container and needs to be restarted
2019-02-20 16:13:22,473 DEBG ‘plexmediaserver’ stderr output:
failed to open /data/jenkins/conan_build/290789224/conan/.conan/data/libva/2.1.0-33/plex/stable/package/81a2df5e16044d97d1b088b0e6c9598b5b17f233/lib/dri/hybrid_drv_video.so
Failed to wrapper hybrid_drv_video.so
this has been working for over a year and only recently started.
Somehow you managed to get an invalid release, the current beta is 1.15.0.659, do another docker pull.
that’s a backdated one from current i back dated to try and solidify the HW transcoding
1.15.0.659 was crashing faster (less than a day) the one im running lasts generally 2-3 days before crashing
running Version 1.15.0.659 again
still flooding with this when i use hardware transcoding
2019-02-21 10:50:51,125 DEBG ‘plexmediaserver’ stderr output:
Official plexinc docker build or something else. Without the logs it will be tough for Plex support to tell but it looks like you have a version conflict with the intel driver.
I can try the official one im using Binhex Plexpass and have for a long time it only recently started…my other unRAID server running i3 8100 is not have same issue with my 4K but also only has a stream when im watching it but the main one with the i7 6700K can have 8-12 streams at any given time for my family
my only issue is running new docker will need to rebuild meta data for 2200 movies and 28,000 tv episodes
Before you do that. I don’t have unraid so I would seek a second opinion. /config should hold your database and settings which should be untouched if you drop and recreate your container. I only commented because the .647 was an accidental release and had a problem. As it was Plex said the optimum method was to delete and recreate your container when going from 1.14 to 1.15.
The 1.15 changed some underlying dependencies, are both your servers on the same version of unraid?
not any more but were the one working is 6.7.0 rc4 and the one im having issues with is stable release 6.6.6 I can try the official docker and install to the same container file for the same config I cant use the unraid 6.7.0 rc4 on my mainserver due to other issues i have with some dockers writing to that server from the other through mapped NFS drives in a VM
Ill try the main and offical plex container installed to the same /config folder to see if that works thanks
Ill report back here. also I enabled the hardware transode this morning with the current plex pass beta and still ok but i usually here about plex not working from my family a day or so after I have restarted the docker container
So, four days later hardware trans coding in abled I’m still getting the error is posted however the doctor container has not locked up once so I think the issue is resolved I don’t know why it just started working
so its still crashing but only once every few days…im suspecting its a memory leak issue on my host machine as I transcode to ram instead of the SSD
