Plex Docker Dies every overnight
Server Version#: 1.41.0.8992
Player Version#: NA
Every overnight around 4am-5:30am my Plex container will shut down. Today, I was able to go in and see a crash report was written (I’ll be it to the wrong directory), and was able to pull the logs out. I am not sure why this issue is happening. Using Unraid’s capability to see the docker container’s logs, this is what I see:
Trying to locate that Plex Crash Report folder, that folder is empty. However, I was able to locate in the Crash Report Uploader logs, that it was stored in TMP and was able to locate it.
Here is the crash report that was in the tmp directory:
bbe64500-5f29-4fe1-29c2f99f-718e4a3c.log (3.5 MB)
After looking at the Crash Report, I do not see any reason why the crash would happen. I also do have a backup utility app for my appdata folders, however it has never backed-up Plex before and should be disabled for the ‘Plex Media Server’ folder(s).
I will also add that during this time, Uptime Kuma does see many other docker containers start crashing and restarting, however all CPU/RAM logs show the machine is not under distress. It appears that somehow Plex is causing a ripple effect to my other containers. I have also gone in and tried to disable all thumbnail, credit/intro detection, etc, to lower the nightly CPU load, but nothing has helped.
Machine is:
OS: Unraid 7.0 Beta 2
CPU: i9- 14900k (New CPU after RMA a month ago)
MoBo: ProArt Z790-CREATOR
RAM: 96GB DDR5
HDD: 212tb Usable, 36tb parity
SSD: 4tb Cache NVME
Do you have the server log directory?
