Plex Docker with HDHomeRun Quattro can't tune after some time
I’m using Plex Docker (latest stable version). I installed HDHomeRun Quatro. When I restart the docker container the tuner works fine for a while. If I go back an hour later, Plex says it can’t tune the channel. But I can go to the HDHomeRun app and the tuner is working fine. I’ve checked all of the logs and can’t find anything in Plex. I have debug mode enabled as well. If I restart the container it can immediately use the tuner.
If I restart the container but don’t use the tuner it’s the same result. Plex can’t tune the channel when I’m ready for it to. So it only works for the first 30 minutes or so while the container is up. What else can I look at?
