Plex does not match properly IMDB tags (tt0871427)
Server Version#: Latest beta
Player Version#: Latest
OK. This question is not for the PLEX dev people What is going on with metadata matches? What used to work perfectly fine before the last 2 updates to the plex server (1.18.2.2058) currently seems to be broke. I understand it might be an issue with third parties like The Movie Database or IMDB but I simply want to bring it up to your attention. Another mini series which is completely mismatched by Plex even when using IMDB tag is " Babylon 5: The Lost Tales ([2007]). IMDB tag tt0871427. When plugging this tag into Plex “search” box, it comes with a completely different show. Hence my “what is going on here?”
Can someone comment, please? It feels like you make two steps forward and three backwards. This is not good.
A “Mini series” cannot be placed in a ‘Movie’-type library.
TheTVDB doesn’t list this as a mini series, but as a movie https://www.thetvdb.com/movies/babylon-5-the-lost-tales-voices-in-the-dark
But Plex doesn’t fetch metadata for movies from TheTVDB.
If you treat this as a “movie”, then you will still get no match with the default “Plex Movie” agent. Because it has only data for “Cinema movies”. But this production went straight to video.
So I recommend you to use the ‘Match/Fix Match’ command in Plex.
Then click on ‘Search Options’ and pick as agent The Movie Database.
Don’t forget to set the language selector.
TMDB has this listed as a movie. https://www.themoviedb.org/movie/15289-babylon-5-the-lost-tales-voices-in-the-dark?language=en-US
