Plex agent unable to match to an imdb ID
Server Version#: 1.41.3.9314
Player Version#: 4.143.0
I have two title that won’t match to specific IMDB ID.
It’s ID tt1079959 and tt1219817
I’ve try the Fix Match method with imdb-tt… in the search content, I try to add the ID under the file name and the .nfo also.
Is there a reason why I can’t match with those ID?
Thank
You are trying to add them into a library of the type “Movies”, right?
These are mini series. As such, they only get metadata in a library of the type “TV Show”.
Thank you, it work as TV series.
Annoying, but it work.
