Plex doesn't recognize specials folder
Server Version#: 1.15.4.919
Player Version#: Web 3.83.1
hey, currently im moving my plex to a new server. moved data, configured plex server, setup new libraries and everything works well except the (all) specials folders.
on the new server every series specials folder content is merged in season 1 - same structure/naming as on the old server ( no problems there ).
any ideas to tackle the problem ?
Your naming convention is not right.
https://support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
Also, use the same naming convention for specials as you do for other seasons.
Should be (at the very least)
/volume1/Storage/Series/Mr Pickels/Season 01/s01e01.mkv
/volume1/Storage/Series/Mr Pickels/Specials/s00e01.mkv
thanks for your advice
yes but it works on the old server with this naming style
same server version
-> dont want to rename the whole library, it should work like on the old one
Sorry
sorry for expecting the same behavior like it has behave the last 2 years
Things change. While it may have worked then doesn’t mean it will now. The naming rules have been around longer then two years. The fact it worked for you then is great and you may of just got lucky the first time around.
You are using the same server version as you did 2 years ago? Much has changed since then. Many new features and BUG fixes were implemented.
The folder(SeasonXX, Specials) means nothing if it doesn’t have an episode to tie it with.
Here is a great example of this. From my own library. Something I haven’t corrected yet.
Btw the name of the series is “Mr Pickles”, not “Mr Pickels”.
You should write the title correctly, to improve matching.
I meant my library has worked for the last 2 years ( and worked with this server version on my old hardware ) so is should work on the new hardware as well.
so i guess its a server configuration problem or something like that
→ also found a work around, setup links for all ‘specials’ folder to ‘season 0’
Okay. Now try to add an episode in the Season 1 folder.
what did you expect to happen ? there are episodes in season 1 & 2
can play them.
but it looks that the configuration problem also cause some seasons to miss ( all have season names in it ).
You can call it a configuration problem all you want. Plex has a naming convention based on which it’ll properly match shows and movies. If you deviate from that, you’re always at risk of things going south. If such a wrong naming schema had worked for you in the past
 call yourself lucky but don’t expect it to be safe.
In the end and for sake of future proofing your library, you might want to consider following the naming conventions.
(no offense
 just trying to cut this short)
https://support.plex.tv/articles/200220707-naming-tv-show-specials/
To add to Tom’s reply,
Anything in the “Specials” directory must follow “S00Exx” format.
As example:
total 88
drwxr-xr-x 10 chuck chuck  4096 May 23  2018 ./
drwxrwxrwx 41 chuck chuck  4096 Feb  1 16:30 ../
drwxr-xr-x  2 chuck chuck 12288 May 23  2018 Season 00/
drwxr-xr-x  2 chuck chuck  4096 Sep  2  2018 Season 01/
drwxr-xr-x  2 chuck chuck  4096 May 23  2018 Season 02/
drwxr-xr-x  2 chuck chuck  4096 May 23  2018 Season 03/
drwxr-xr-x  2 chuck chuck  4096 May 23  2018 Season 04/
drwxr-xr-x  2 chuck chuck  4096 May 23  2018 Season 05/
drwxr-xr-x  2 chuck chuck  4096 May 23  2018 Season 06/
drwxr-xr-x  2 chuck chuck  4096 May 23  2018 Season 07/
[chuck@lizum Star Trek Voyager.394]$ cd Season 00
cd: Too many arguments.
[chuck@lizum Star Trek Voyager.395]$ cd *0
[chuck@lizum Season 00.396]$ ls
Star Trek Voyager.S00E01.Star Trek Inside The New Adventure.mkv
Star Trek Voyager - S00E01 - Star Trek Inside The New Adventure.mkv
Star Trek Voyager.S00E101 - Braving The Unknown Season One.mkv
Star Trek Voyager.S00E102 - Voyager Time Capsule Kathryn Janeway.mkv
Star Trek Voyager.S00E103 - The First Captain Bujold.mkv
Star Trek Voyager.S00E104 - Cast Reflections Season One.mkv
Well, what I expected at the time I added them eons ago was Plex seeing a season 01 and a season 02 but the way I named them plex sees only season 01 and duplicates of those. I closer look.
