Plex doesn't work on ps4
Hi. 2 days ago plex do an update on my ps4. And now it doesn’t work anymore. Every time I need to unistall the app and reinstall it again. it’s work for 20 minutes and after that the app doesn’t work again. Please help me
I have similar issue. I must uninstall and reinstall for each time I want to see anything.
Please help for it, or help to downgrade plex app (last version by far was ok).
I have a similar issue. Every time I go to use plex since the update I have to log out and then log back in using the 4 digit code. If I don’t do that I just get an endlessly spinning circle
Exact same issue. I assumed I was the only one having it seeing as it’s been going on for weeks and hasnt been fixed. How long do they normally take to fix these problems?
same issue here
