Plex DVR and Other Apps. ??
Version 1.9.3.4290
Great job on the fixing the problem with multiple tuners … I have 4 Connects and 2 Primes and I tested and they all work.
But there is one Problem I do not want to be lost in other tuner sharing posts.
Working great as long as it is the only APP that uses the tuners. If you are watching using another app like the HDHomerun App if Plex tries to use that tuner it just fails and still does not move on to next available tuner. I need to share my primes because the HDHomerun App is the only one that I can watch DRM channels. Plex needs to query the tuner and if in use by another APP move on to next available tuner.
logs sent to Plex Server.
I assume Plex now keeps track of the tuners it has allocated to it and which ones it is currently using … but it appears Plex is still not checking to see if other APPS are using the tuners.
