Hey Guys,
Just wondering if this has been implemented properly? As I have to manually map the channels and it’s an absolute pain in the ass.
If I could use this XMLTV guide: http://www.xmltv.co.uk/ that would be great but Plex says the XML file is missing or corrupt?
Have you tried using just the first 3 characters of your post code? I’ve not had to map any channels manually.
i redid mine recently and had to manually map about 2/3s of the channels
Willhelm, cheers mate I was starting to pull my hair out as the dropdown window for manually doing it is so small.
Using the first half of my Postcode let me select the Youview EPG which is a ton more accurate with channel matching than the freesat one!
Same Problem in Germany …EPG and Channel does not match
