For some reason, Plex always failed to record TNT’s Animal Kingdom, even when shown as ‘reruns’, season 2 is failing also and now the same is happening with the new show 'Will", the channel is unprotected.
If you haven’t already, maybe try re-scanning your channels? TNT is protected in my area. Maybe they protected the channel since your original scan.
A channel ‘rescan’ this AM still found TNT ‘unprotected’ but shows fail to record and disappear from ‘scheduled recordings’ matrix after time slot, no errors mentioned.
Interestingly, other shows, ‘Good Behavior’ are being recorded on the same unprotected TNT channel but in addition to ‘Animal Kingdom’ not recording, the new show ‘Will’ is not being recorded either.
I know this is a month old but I was just trying to record The last ship on TNT last night and it was failing as well. I tried tuning the channel with plex and would say something to the effect of transcoder crashed. I tried adjacent channels with no issue and also used HDhomerun and Live Channels (on Windows and android TV respectively) to tune to TNT with no problem. I will try rescanning my HDHomerun prime (though I did just update the firmware, and the channel didn’t show the lock on my.hdhomerun.com) as well as my plex server tonight. I tried recording a Supernatural rerun this morning and it failed immediately, so it’s something with the channel for me it seems
Ok so I re-scanned the channels, TNT (ch 624) is not protected and I tried to start recording Supernatural at 11:18:27.781 8/21 and it failed saying transcoder error again. I have attached my logs if anyone at plex can take a look. I browsed the plex media server.log (not sure where else to look) and the errors near that attempt are shown below. I won’t copy too much because of space but maybe someone can make sense of it? I’m running the latest (v1.8.1.4139) on Win10x64.
Aug 21, 2017 11:18:27.797 [9396] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Aug 21, 2017 11:18:27.797 [9396] DEBUG - Selecting best audio stream for part ID -1 (autoselect: 0 language: en)
Aug 21, 2017 11:18:27.797 [9396] DEBUG - Falling back to picking the first audio stream 1.
Aug 21, 2017 11:18:27.797 [9396] DEBUG - Audio Stream: -1, Subtitle Stream: -1
Aug 21, 2017 11:18:27.797 [9396] ERROR - Unable to find title for item of type 5
Aug 21, 2017 11:18:27.797 [9396] DEBUG - MDE: analyzing media item -1
Aug 21, 2017 11:18:27.797 [9396] DEBUG - MDE: : no direct play video profile exists for http/mpegts/
Aug 21, 2017 11:18:27.797 [9396] DEBUG - MDE: : no direct play video profile exists for http/mpegts//
Aug 21, 2017 11:18:27.797 [9396] DEBUG - MDE: : codec is unavailable for analysis
Aug 21, 2017 11:18:27.797 [9396] DEBUG - MDE: : selected media 0 / -1
Aug 21, 2017 11:18:28.953 [2888] ERROR - [Transcoder] [mpeg2video @ 015b1da0] Invalid frame dimensions 0x0.
(COMMENT FROM ME: there’s a bunch of these)
Aug 21, 2017 11:18:31.063 [9396] DEBUG - DVR:Recorder: It took 3.3 sec to start the session for http://192.168.1.38:5004/auto/v624
Aug 21, 2017 11:18:31.063 [9396] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Aug 21, 2017 11:18:31.063 [9396] DEBUG - Selecting best audio stream for part ID -1 (autoselect: 0 language: en)
Aug 21, 2017 11:18:31.063 [9396] DEBUG - Falling back to picking the first audio stream 1.
Aug 21, 2017 11:18:31.063 [9396] DEBUG - Audio Stream: -1, Subtitle Stream: -1
Aug 21, 2017 11:18:31.063 [9396] ERROR - Unable to find title for item of type 5
Aug 21, 2017 11:18:31.063 [9396] DEBUG - MDE: analyzing media item -1
Aug 21, 2017 11:18:31.063 [9396] DEBUG - MDE: : no direct play video profile exists for hls/mpegts/mpeg2video
Aug 21, 2017 11:18:31.063 [9396] DEBUG - MDE: : no direct play video profile exists for hls/mpegts/mpeg2video/ac3
Aug 21, 2017 11:18:31.063 [9396] ERROR - PropertyContainer::get - invalid frameRate value: 29.970
Aug 21, 2017 11:18:31.063 [9396] DEBUG - MDE: : selected media 0 / -1
Aug 21, 2017 11:18:33.098 [5660] DEBUG - Request: [127.0.0.1:51147 (Loopback)] PUT /video/:/transcode/session/ed588188-8aeb-4b33-9ee8-65205880e21d/d5c3734e-5daf-4ea4-8cd6-43d1ce022b9c/progress/streamDetail?index=2&id=0&codec=ac3&type=audio&bitrate=192000&channels=2&layout=stereo&sampleRate=48000 (18 live) Signed-in Token (youareme7)
Aug 21, 2017 11:18:33.098 [2888] ERROR - [Transcoder] Stream map ‘0:3’ matches no streams.
To ignore this, add a trailing ‘?’ to the map.
Aug 21, 2017 11:18:33.145 [3164] DEBUG - Jobs: ‘C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe’ exit code for process 10016 is 1
Aug 21, 2017 11:18:33.145 [3164] DEBUG - DVR:Recorder: Asked to stop recording ‘Supernatural - E4 - Baby’.
Aug 21, 2017 11:18:33.145 [3164] DEBUG - DVR:Recorder: Stopping transcode session.
Aug 21, 2017 11:18:33.145 [3164] DEBUG - Killing job.
Aug 21, 2017 11:18:33.161 [3164] DEBUG - Job was already killed, not killing again.
Aug 21, 2017 11:18:33.161 [3164] DEBUG - Stopping transcode session 66e5c259-5006-4235-b16b-768fa5dd7676
@John-Y128 @youareme7 I have encountered transcoder errors like this as well on VICEHD channel. When trying to record on VICE (standard def), however, there is no issue. I noticed though that VICE records in mkv format instead of mpeg2. This may be the case with TNT as well, but I currently have no way of testing this. I’m wondering if, for some reason, Plex can’t handle recording mkv files in HD. Maybe it has to do with the hardware we’re running (I’m running on a quad core Synology RS815+). I’m not sure. I haven’t had too much time to test my theory, but I think it might have something to do with the mkv container. Maybe try recording TNT in SD and see if that works. If so, see what container it’s in, TS (mpeg2) or mkv.
@youareme7 said:
Ok so I re-scanned the channels, TNT (ch 624) is not protected and I tried to start recording Supernatural at 11:18:27.781 8/21 and it failed saying transcoder error again. I have attached my logs if anyone at plex can take a look. I browsed the plex media server.log (not sure where else to look) and the errors near that attempt are shown below. I won’t copy too much because of space but maybe someone can make sense of it? I’m running the latest (v1.8.1.4139) on Win10x64.Aug 21, 2017 11:18:27.797 [9396] DEBUG - We’re going to try to auto-select an audio stream for account 1.
I have been looking at your logs. We need to capture the cache ranscoder files that were being processed
If this is easily reproduced and getting this
Aug 21, 2017 11:18:33.098 [2888] ERROR - [Transcoder] Stream map '0:3' matches no streams.
To ignore this, add a trailing '?' to the map.
followed by failure
Aug 21, 2017 11:18:33.130 [9888] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe' exit code for process 10016 is 1
would like you to watch the contents of this directory
C:\Users\youar\AppData\Local\Plex Media Server\Cache\Transcode\Sessions
There would be ts files generated and would need all these files zipped together with the logs.
The subdirectories get purged soon after the transcoder fails so need to copy them out before that happens
So please copy the directory contents out picking all the cache files for the transcode session and zip and provide with the logs zip
This (as example) shows what file structure would be here and the ts files generated
Aug 21, 2017 11:18:31.204 [1588] DEBUG - Content-Length of C:\Users\youar\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-66e5c259-5006-4235-b16b-768fa5dd7676\media-00000.ts is 598592.
Aug 21, 2017 11:18:33.083 [1588] DEBUG - Content-Length of C:\Users\youar\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-66e5c259-5006-4235-b16b-768fa5dd7676\media-00001.ts is 1558708.
Would need all these files that the transcoder was processing before the exit/crash
If this is easily reproduced and getting thisAug 21, 2017 11:18:33.098 [2888] ERROR - [Transcoder] Stream map '0:3' matches no streams. To ignore this, add a trailing '?' to the map.followed by failure
Aug 21, 2017 11:18:33.130 [9888] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe' exit code for process 10016 is 1would like you to watch the contents of this directory
The subdirectories get purged soon after the transcoder fails so need to copy them out before that happensSo please copy the directory contents out picking all the cache files for the transcode session and zip and provide with the logs zip
Aug 21, 2017 11:18:31.204 [1588] DEBUG - Content-Length of C:\Users\youar\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-66e5c259-5006-4235-b16b-768fa5dd7676\media-00000.ts is 598592. Aug 21, 2017 11:18:33.083 [1588] DEBUG - Content-Length of C:\Users\youar\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-66e5c259-5006-4235-b16b-768fa5dd7676\media-00001.ts is 1558708.Would need all these files that the transcoder was processing before the exit/crash
@sa2000 Thanks for the reply! I’ve attempted to record Charmed this morning at 8:26 on TNT with the usual failure. I have copied the requested cache files and zipped them along with a new dump of the logs. Please let me know if you need anything else!
Thank you very much. I think I have enough now to refer it to the development team
Got feedback from the development team
Please could you try Beta release 1.9.5 available from https://plex.tv/downloads
If problem is still there, please get me fresh server logs and indication as to when the error arose
If problem is still there, please get me fresh server logs and indication as to when the error aroseThanks
I have feedback from another user that this failure has been resolved after updating Plex Media Server
Please could you confirm and if not fixed, please get fresh diagnostics
Please could you confirm and if not fixed, please get fresh diagnosticsThanks
Hi, I just returned and have had the chance to attempt a recording and it was successfully so I also concur that the issue has been fixed. Thanks!
