Plex DVR not working on FreeNAS with FritzBox
Server Version#: Latest
Hi, just tried to get live tv/dvr working with my fritzbox 6490 but on FreeNAS Plex just can’t find it.
On my Mac it works.
Is there anything I need to install or configure?
I’m not sure what’s the problem - on a earlier Installation it worked - not good, but was working.
After some updates on Plex it’s not possible to add the FB 6490 anymore. It’s not supported officially and in the community support list the FritzBox is not included. As the technical specifications it should be possible - but I didn’t yet found a solution for it :confused:
So if any have a idea where could be the problem…
