Plex DVR not working
I am seeing that WHEN shows don’t record that the on now section of live TV section the show details shows tomms date. I assume this is an epg issue or some problem with how the date id maintained. Any ideas how to fix
Or it could be something where your Host’s/PMS timezone is different than say your TV Tuner (HD Homerun,etc.)
I would verify that all the devices are set to the same time zone and are showing the same time information as a starting point…
Hi
I checked the host and it is set to local time. The tuner doesn’t have a way to set the clock but when I reboot I can see it does an ntp and sets it time to Zulu. I believe there is an issue in the “On Right Now” part of the Live TV tab. For example it look like Today Third Hour is playing but if I drill down in the description I see the date is for tomm. I also don’t see the play option only info and record. If i go to the Guide I can us it tune to the Today show
