Plex DVR, Playback Error: Unable to tune channel
I am consistently getting a Playback Error: Unable to tune channel on higher number channels. I have no clue what the problem could be or when this problem started. These channels work fine in the native HDHomerun App. Are there any ideas to help solve this one?
Plex Media Server Logs_2018-07-08_20-49-30.zip (829.4 KB)
Update-
After hours of messing around with settings and reinstalling I decided to take the plunge, risk everything and remove my DVR devices from Plex and add them back. Once I did this I was able to select channel 816 (HD) but the SD version 045 (SD) played and 816 will still not tune. My Apple TV will still not tune to 816.
i also can not tune any channels in plex only, i have a HDHomerun Connect Quatro updated to latest firmware.
Plex pass…
My other tuner software " channels " on the Shield tunes immediately no issues, plex will detect the tuner and scan channels like it should but not play or record.
i have removed the tuner and re scanned the channels but still no play/record…
any help here would be great…
Ditto on these problems… bought an hdhomerun because it is a “support device” but all i find all over the forums is people having this problem and there not being much support from plex on it.
