Server Version#: 1.17.0.1841
Player Version#:2.40.1.70
Some time between September 11 and September 18th I could no longer direct stream content to my Xbox one x that was recorded from it’s channels using Plex DVR. It will start playing as a direct stream but then a few seconds in switch to transcoding the video. The same shows recorded the week prior will continue to play as direct streams, but any new recordings will not direct stream.
Because of this I cannot watch a show on the Xbox while another is recording without causing problems with the show that is recording. I have tried turning direct stream and direct play on and off and nothing has fixed this issue.
Any help would be greatly appreciated.
