having the same problem…only going back 10+ versions seems to solve it…and i don’t want to have to do that every time, after i hope the next instance of plex may work for me.
Seems to be a core issue with Plex. I’ve read complaints about this that spans several server versions of Plex and many different storage devices, from PC servers, NAS devices, and removable storage devices. Hopefully they’re aware of it and get it fixed soon.
Same with HDHomeRun (on newest firmware 20170930 and the previous one), and Server Version 1.9.2.4285 running on Synology. Restarting the Plex package correctly ends the recording and adds it to the library, but otherwise is just shows the percentage continuing well past 100%. In the tuners section it also shows that “2 tuners—3 recording now” which is obviously not possible. Looking at HDHR’s status, none of the tuners are in use after the proper end-time, but Plex doesn’t seem to know that its own activities have ended.
I still have the same issue. The only resolution I’ve had any luck with was restarting the PLEX server, which won’t really work for back to back recordings…
