I have seen that the recent update has added support for Hauppage HVR-22XX cards, my Plex server runs on freenas and my PCI-e card is inside my HTPC within my local network. Is my configuration supported? When I try to add a card it mentions you can specify an IP manually but I can’t help but wonder if this is only for the network tuner devices such as the HDHomeRun.
So, given that my Plex can’t find anything when I try to setup my Plex DVR is this because the PCI-e cards must be local?
Currently the card needs to be in the computer running plex (remote usb might be possible with usbip). When SAT>IP support is added to Plex you will be able to turn any tuner supported by v4l-dvb in to network tuner using minisatip!
Thanks guys. Thought so but couldn’t find any assistance with documentation. Bit of a gap I feel with it being a relatively new and growing feature set.
