Plex en RaspBerry pi 2 b no inicia
He instalado plex media server en una raspberry pi 2 b con Raspbian Stretch y no consigo que inicie . La instalación ha sido totalmente correcta sin nigun error desde el repositorio de plex, pero cuando intento iniciar el servicio siempre me da un error.
journalctl -xe me ha devuelto lo siguiente:
– Subject: Unit plexmediaserver.service has begun start-up
– Defined-By: systemd
– Support: Debian -- User Support
– Unit plexmediaserver.service has begun starting up.
dic 05 19:36:47 rasppiSpark systemd[1]: Started Plex Media Server.
– Subject: Unit plexmediaserver.service has finished start-up
– Unit plexmediaserver.service has finished starting up.
– The start-up result is done.
dic 05 19:36:47 rasppiSpark systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
dic 05 19:36:47 rasppiSpark systemd[1]: plexmediaserver.service: Unit entered failed state.
dic 05 19:36:47 rasppiSpark systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
dic 05 19:36:48 rasppiSpark sudo[23949]: pam_unix(sudo:session): session closed for user root
dic 05 19:36:49 rasppiSpark sudo[23969]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl status plexmediaserver
dic 05 19:36:49 rasppiSpark sudo[23969]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
dic 05 19:36:52 rasppiSpark systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
dic 05 19:36:52 rasppiSpark systemd[1]: Stopped Plex Media Server.
– Subject: Unit plexmediaserver.service has finished shutting down
– Unit plexmediaserver.service has finished shutting down.
dic 05 19:36:52 rasppiSpark systemd[1]: plexmediaserver.service: Start request repeated too quickly.
dic 05 19:36:52 rasppiSpark systemd[1]: Failed to start Plex Media Server.
– Subject: Unit plexmediaserver.service has failed
– Unit plexmediaserver.service has failed.
– The result is failed.
dic 05 19:36:52 rasppiSpark systemd[1]: plexmediaserver.service: Unit entered failed state.
dic 05 19:36:52 rasppiSpark systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
dic 05 19:36:53 rasppiSpark sudo[23969]: pam_unix(sudo:session): session closed for user root
dic 05 19:36:58 rasppiSpark sudo[23978]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl status plexmediaserver
dic 05 19:36:58 rasppiSpark sudo[23978]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
dic 05 19:37:00 rasppiSpark sudo[23978]: pam_unix(sudo:session): session closed for user root
dic 05 19:37:01 rasppiSpark sudo[23984]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl status plexmediaserver
dic 05 19:37:01 rasppiSpark sudo[23984]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
dic 05 19:37:03 rasppiSpark sudo[23984]: pam_unix(sudo:session): session closed for user root
dic 05 19:37:05 rasppiSpark sudo[23992]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl status plexmediaserver
dic 05 19:37:05 rasppiSpark sudo[23992]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
dic 05 19:37:08 rasppiSpark sudo[23992]: pam_unix(sudo:session): session closed for user root
dic 05 19:37:11 rasppiSpark sudo[24001]: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/bin/systemctl restart plexmediaserver
dic 05 19:37:11 rasppiSpark sudo[24001]: pam_unix(sudo:session): session opened for user root by pi(uid=0)
dic 05 19:37:11 rasppiSpark systemd[1]: plexmediaserver.service: Start request repeated too quickly.
dic 05 19:37:11 rasppiSpark systemd[1]: Failed to start Plex Media Server.
dic 05 19:37:11 rasppiSpark systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
dic 05 19:37:11 rasppiSpark sudo[24001]: pam_unix(sudo:session): session closed for user root
dic 05 19:37:17 rasppiSpark dhcpcd[255]: eth0: Router Advertisement from fe80::1
Alguna idea de como puedo solucionarlo?
Ahí no te pone gran cosa, solo que falla en el inicio.
Para eso sube los logs que escribe el propio servidor:
  • Prueba de nuevo a iniciar Plex.
  • Cuando falle, vete a donde están los logs de Plex y súbelos. Deben de estar en:
/var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/
La ruta que me indicas, no existe. Solo existe hasta /var/lib/plexmediaserver/Library/Application\ Support/ y se encuentra vacía.
No encuentro mas logs donde poder mirar.
Cuando inicio el servicio, si consulto el status me aparece por un momento:
sudo systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2021-12-07 18:41:07 CET; 382ms ago
Process: 31867 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -
Main PID: 31873 (sh)
Tasks: 5 (limit: 4915)
CGroup: /system.slice/plexmediaserver.service
├─31873 /bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= “{print $2
├─31875 /bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR=”$(grep ^NAME= /etc/os-release | awk -F= "{print $2
└─31876 grep ^NAME= /etc/os-release
dic 07 18:41:07 rasppiSpark systemd[1]: Starting Plex Media Server…
dic 07 18:41:07 rasppiSpark systemd[1]: Started Plex Media Server.
Pero al momento está reiniciando y me muestra:
Active: activating (auto-restart) (Result: signal) since Tue 2021-12-07 18:41:14 CET; 385ms ago
Process: 31891 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{p
Process: 31887 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -
Main PID: 31891 (code=killed, signal=SEGV)
dic 07 18:41:14 rasppiSpark systemd[1]: plexmediaserver.service: Unit entered failed state.
dic 07 18:41:14 rasppiSpark systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
Y al momento me da error:
Active: failed (Result: signal) since Tue 2021-12-07 18:41:19 CET; 1min 26s ago
dic 07 18:41:19 rasppiSpark systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
dic 07 18:41:19 rasppiSpark systemd[1]: Stopped Plex Media Server.
dic 07 18:41:19 rasppiSpark systemd[1]: plexmediaserver.service: Start request repeated too quickly.
dic 07 18:41:19 rasppiSpark systemd[1]: Failed to start Plex Media Server.
dic 07 18:41:19 rasppiSpark systemd[1]: plexmediaserver.service: Unit entered failed state.
dic 07 18:41:19 rasppiSpark systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
La señal SEGV para terminar un proceso, en este caso Plex, hace referencia a un fallo de segmentación, es decir, cuando Plex intenta acceder a ubicaciones de memoria no válidas.
Puede ser que la tarjeta SD de tu Raspberry esté dañada, prueba con otra.
Gracias por tu rápida respuesta.
Ya he probado con otra micro SD e instalando un raspberry pi os desde cero e instalando unicamente plex. Practicamente obtuve el mismo error que reproduzco en el foro.
He llegado a pensar que es un problema con la versión de raspberry pi 2 b o un problema hardware de la propia raspberry.
Creo que cuando se instala plex media server utiliza el armv7 y creo que la raspi 2 b utiliza armv6. No se si esto es correcto o como forzar la instalación correcta para mi raspberry.
Gracias de nuevo
Puede ser que el problema sea de la antigüedad de la Raspberry pi 2b.
Si es la Pi 2b creo que tiene la ARM Cortex-A7, que implementa armv-7.
Prueba a instalar Plex con Docker.
O prueba con una versión un poco más antigua de Plex.
