Server Version#: 1.15.1.710
Player Version#: 3.89.2 (Effects everyone of my various clients the same)
Plex Transcoder Statistics.1.log (15.4 KB)
Specs: Dual Xeons X5680/48GB Ram(16GB ram drive for transcodes)/Nvidia P2000/Windows 10 Pro/ Native Plex server app/Plex Pass member
So I will start this by saying I know you should transcode 4K HDR because you lose color data. I was just doing this to test HW transcoding!
The issue I am having only affects HEVC or converting H.265 to H.264. Plex trys to transcode the video but is incrediably slow. Tautulli shows its only converting at .5-.8. The other weird this is my usage goes down dramatically. CPU usage only goes to about 10% and GPU usage on decode is only 15%. When I transcode H.264, it works properly and my cpu and GPU usage is much higher. I tried messing with the different transcode settings but they don’t change much. I have also tried new drivers for my P2000 and doing a clean install of drivers. I have had this behavior for several months and the newest update that just came out didnt help(on beta).
Emby works perfectly though so I know its not a hardware issue. It can transcode 4-6 4K HEVC H.265 movies at once. I have posted a few times about this issue but haven’t had a single response
