Plex + filebot: adding info to the filename, is it possibile?
I recently moved to filebot. It would be very useful to me adding some information to the file name, such as codec, resolution, bitrate.
I use the following format:
E:/{plex.derive{" [$vf, $kbps, $vc, $ac]"}}
which gives, for example,
E:\Movies\Some Like It Hot (1959)\Some Like It Hot (1959) [360p, 850 kbps, DivX, MP3].avi
and Plex correctly recognize the movie. Great.
The problem arise dealing with movies splitted:
E:\Movies\Avatar (2009)\Avatar (2009) CD1 [360p, 1076 kbps, XviD, MP3].avi
Plex can’t recognize this properly. I know the guidelines and it should be named
E:\Movies\Avatar (2009)\Avatar (2009) - cd1.avi
Here are my questions:
1_ why filebot rename uncorrectly with the “CD1”, capital and without the “-”?
2_ the Plex scraping is more robust than it claims to be (see my first example). Is it possible somehow to keep my renaming format and bypass the splitted movie issue?
https://www.filebot.net/forums/
You could ask over there. I do know if you don’t have the ‘-’ in your FB tags it won’t go in the file name and the same is probably true for ‘cd1’ as well. I assume. I’ve not had to fiddle with that function.
Yea.
Dump the AVI files into MKVToolNix and hope you can join 'em together - to make one:
I don’t know if that will work with your AVI files - so Dump the AVI files and get one of anything else.
At least you have a few options.
You could also change that to
E:\Movies\Avatar (2009)\Avatar (2009) - [360p, 1076 kbps, XviD, MP3]-cd1.avi
But of course that’d require the file for cd 2 to use the exact same file name.
Would FB recognize crudely named 2 parters and deal with them appropriately?
I wonder?
good try but it does not work.
Neither
E:\Movies\Avatar (2009)\Avatar (2009) - [360p, 1076 kbps, XviD, MP3] - cd1.avi
@JuiceWSA I would like not the join the splited movies manually… At most rename them…
Does not work, how?
What is the file name of disc 2?
Plex does not recognize them as a single movie.
E:\Movies\Avatar (2009)\Avatar (2009) - [360p, 1076 kbps, XviD, MP3] - cd2.avi
E:\Movies\Avatar (2009)\Avatar (2009) [360p, 1076 kbps, XviD, MP3] - cd1.avi
too many hyphens - I guess…
Don’t think so.
Remove the spaces around the second hyphen.
My first try. It does not work.
Neither
E:\Movies\Avatar (2009)\Avatar (2009) - [360p, 1076 kbps, XviD, MP3]-cd2.avi
Is this a real “movies” library or an “Other Videos”-type?
Real movies
And E:\Movies\Avatar (2009)\Avatar (2009) - cd1.avi isn’t working either?
Hey, sorry. I get it. CD1 and CD2 have different bitrate actually, so the name was not the same!
Adding the bitrate info is not a good idea maybe…
Not for two-parters anyway.
What file names are working now?
I’ve just “fix” the name having the same bitrate.
When I wrote this before I was actually lying :smiley:
it works as well as
A question for you: which FB “edit format” do you use? I could to spend days thinking to the best option and change my mind multiple times. Maybe you already tought aboyt that…
As soon as you install mediainfo you’ll never need those technical details in the file name anymore, IMHO.
Ok but maybe I want to “search by codec” in order to renew part of my library…
I am thinking to add the director name. Maybe someone ask me to give him the Woody Allen movies…
That’s what I thought until I added 1400+ (and counting) HEVC replacements - then had to fix 1300+ of them - and boy was I glad they were clearly marked - so I could Delete them in Bulk.
Thank you Filebot and Calgon… take me away…
:wink:
By the way, this is my “edit format” (atm)
E:/Film/{ny}/{n}{info.OriginalName =~ n ? ‘’ : " - $info.OriginalName"}{" ($director, $y)“}{” [$vf, “}{pn =~ 1 ? “$mbps, " : ‘’}{”$vc, $ac]”}{" - cd$pi"}
which seems to correctly handle both the non-english movies (italian in my case) and the splitted ones (cd1, cd2).
