hsousa
May 30, 2018, 10:33pm
81
Version 5.0.1 is now available
FIXED:
Fixed crash on iOS 9 devices.
Version 5.0.2 is now available
FIXED:
Fixed playback of News from channels.
Version 5.0.3 is now available
FIXED:
Fixed issue accessing synced content in airplane mode.
Version 5.1 is now available
NEW:
Allow seeking from the lock screen during playback.
Allow stepping back/forward from the lock screen controls while playing podcasts.
The More tab now shows the number of hidden types.
FIXED:
Add Go To Hub context menu option for Watch Later and Recommended hubs.
Add pull to refresh to the sources list.
Changes to Account & Settings menu look and presentation.
Couldn’t modify recording policy for a TV Show where no episodes were scheduled for recording at the moment.
Fixed an issue that could cause the All Photos view to never load.
Fixed an issue where the homescreen would appear to be loading infinitely on first launch for users without a server.
Fixed performance issues when opening the source picker.
Fixed playback of News clips from search.
Hub titles now update correctly when adding or removing hubs from a second server.
Improved accessibility through VoiceOver.
Improved dialog to set limit of synced items.
Improved loading animations for home screen hubs.
Include synced libraries original server titles in the sources list.
Make the source picker button two lines and ensure it doesn’t go under the search button.
Managed users will now see server names instead of usernames in the sources list.
Saving smart playlists didn’t work.
Search button was shown in search view.
Show an offline zero state instead of a spinner when accessing Plugins while offline.
Some subtitles were cut off in Live TV cells for home users.
The More tab now lets you finish editing with any number of types hidden.
Turning on offline browsing from a type inside the More tab no longer returns you to the More screen.
Version 5.2 is now available
NEW:
Now you can download podcasts, including immediate download of episodes or set up automatic download for shows.
Downloaded podcasts can be viewed and played when no internet connection is available or when switched to offline mode.
You can manually delete podcasts shows and episodes just like synced content via the Downloads and Sync area.
Import your current podcasts subscriptions from other apps via the OPML import feature.
Add support for Podcast-level playback speed setting.
Added support for repeat modes in Chromecast.
Audio player now shows the current playback speed.
When switching between online/offline modes, the app will switch to the offline content for the source you’re currently browsing if possible.
FIXED:
Add a hint overlay the first time using the app.
Camera Upload can be configured by allowed Home Users again.
Hide incorrect error message when switching Live TV channels.
Music Videos and Similar Artist are right in the Artist View.
Tapping on the volume icons wouldn’t change the volume in remotely controlled players.
Tweak colors of source picker labels to better differentiate titles.
Version 5.3 is now available.
FIXED:
Fixed an issue that could prevent video playback within photo libraries.
jam
September 13, 2018, 6:19am
87
Version 5.4 is now available.
NEW:
Added ability to select a preferred server when logging in for first time, and restoring to defaults from the home screen
Added support for rich Podcast descriptions.
You can now long press on a type on the tab bar to quickly switch to it and bring up the source selector.
FIXED:
Correctly show subscription status with 6 month Plex Pass.
Couldn’t skip to other Podcasts tracks while using Chromecast.
Fixed issue where syncing new items required to restart the app in order to see them in offline mode.
Recording schedule badge would sometimes appear for shows not scheduled for recording.
The Podcast player now shows the episode date.
Unfinished podcast episodes would show up as finished in their preplay screen.
Editing a DVR recording would wrongly show podcast-related UI.
Version 5.5 is now available.
NEW:
When adding a hub to the home screen, you’ll now be asked if you want a global hub for that server, or a hub from the specific library.
FIXED:
Current and upcoming programs could overlap in Live TV player.
Scheduling a DVR recording could sometimes fail when switching between libraries with multiple locations.
The “Synced Only” filter was not functional.
Version 5.5.1 is now available.
FIXED:
Fixed a crash on launch on 32-bit iOS devices.
Version 5.6 is now available.
NEW:
Allow channel selection when watching a live program airing on multiple channels.
FIXED:
Don’t show a non-functional video quality playback setting for Web Shows.
Fixed a layout issue with the player controls in future iOS versions.
Improve the preferred server picker to indicate offline servers, and only automatically add hubs to the home screen from that server.
Removed discontinued Watch Later feature.
Search wasn’t working properly in offline mode.
Sometimes radio stations could not render properly.
Subtitle Search results show more information.
The source picker could have the wrong title after resetting your preferred server.
The sync action in the context menu was unavailable in the Home tab.
You can once again browse the camera roll photo source no matter your offline browsing setting.
hsousa
November 5, 2018, 5:21pm
91
Version 5.6.1 is now available.
FIXED:
Don’t limit playback to 1 minute on web shows for users who have not activated the app.
hsousa
November 7, 2018, 8:15am
92
Version 5.6.2 is now available.
FIXED:
Fix crash when searching while offline.
Fixed memory issue that could result in a crash.
Fixed an issue that caused Plex Pass subscription features to sometimes be unavailable.
hsousa
November 14, 2018, 9:22am
93
Version 5.7 is now available.
FIXED:
Audio and Subtitle are shown in the Video Screen.
Context menu options were incorrectly made available when browsing by folder.
Fixed an issue that could cause the volume slider to move in the wrong direction when using the volume buttons.
Improved HDR detection.
Player controls would hide behind sensor housing on iOS 12.1
Prevent device from locking while video is buffering.
Version 5.7.1 is now available.
NEW:
We’ve enabled a new audio player with some neat enhancements under the hood which improve performance.
FIXED:
Fix lyrics sometimes not showing.
Version 5.7.2 is now available.
FIXED:
Fix an issue with playing tracks from search results on some servers.
Resolve audio control issues on recent versions of iOS.
Version 5.8 is now available.
NEW:
FIXED:
Fix preferred server picker layout on small screens.
Fixed an issue where playback of all content from a filtered view would ignore the filter.
Recording details screen would wrongly show a white background.
The app may have incorrectly entered offline mode when a VPN connection was active.
Version 5.9 is now available.
NEW:
Grid view guide for browsing DVR channels.
The new video player can now play HDR videos in SDR mode with tone mapping. It doesn’t currently support HDR output.
Added support for direct play of VC-1 videos with the enhanced player. This is only available on iPhone 7 and newer, and on iPad Pro from 2017 and newer.
FIXED:
Fixed issues that may have caused downloaded podcasts to be unavailable while offline.
Fix setting subtitle size with Enhanced Video Player.
Queue all music videos when playing from a TIDAL artist.
Some podcasts could show the wrong duration.
You can now save TIDAL videos to your My TIDAL library from the player.
Fixed “Prefer Synced Content” option not working with music.
Version 5.9.1 is now available.
FIXED:
Fixed a crash for users with no On Deck or Continue Watching hubs.
Fixed playlist playback under some circumstances.
jam
February 6, 2019, 10:23am
99
Version 5.10 is now available.
NEW:
Added Subtitle Offset adjustment support (only available for the enhanced video player).
Added a badge to the player when TIDAL HI-FI content is playing.
Improved Playback Info screen with more useful information.
FIXED:
Enabling Picture in Picture with the enhanced video player sometimes required tapping the button twice.
Fix a crash in the DVR guide that could occur with custom XMLTV providers.
Fixed an issue causing Collections to be in the wrong order.
Fixed an issue causing News to show some videos in categories with a title of “(null)”
Fixed an issue that could cause the app badge to remain forever after receiving a friend request.
Fixed crash when the app is backgrounded while playing a video with the enhanced video player.
Fixed issue causing the volume controls to be too close to the home indicator on iPhone X models.
Hide playlist edit controls for readonly playlists.
Playback would restart in wrong offset when seeking.
Rely on PMS to name Live TV guide labels.
Server update prompts were not appearing.
Show server name on multi-location Live TV search results.
Sometimes subtitles were partially hidden when zooming with the enhanced video player.
TIDAL artist music video hub now plays correct video.
The Offline Browsing setting is now correctly remembered on app launch.
gnuaha7
February 27, 2019, 10:00pm
100
Version 5.11 is now available
NEW:
Added Live TV support to the enhanced video player.
Added Slovak translation.
Added support for deinterlacing videos with the enhanced video player.
Enhanced Video Player uses System’s Subtitles & Captioning settings.
FIXED:
Don’t apply smooth fades during consecutive album track playback.
Don’t ignore line breaks in artist bios.
Enabled more button in My TIDAL to allow Play All / Shuffle All.
Fix issue with Live TV failing to start playback reliably.
Fix layout of Podcast category titles.
Fixed an issue where sources from servers you could no longer access weren’t removed.
Fixed crash after a few minutes of playback with the enhanced video player.
Fixed some scenarios where app would be stuck in offline mode even with internet connection.
Import subtitle was only available from the player.
Improved performance of full time-shifting in LiveTV streams.
Improved seek times in transcoded streams under some circumstances.
Music from other apps would pause when the user opens Plex.
Show artist as subtitle for TIDAL album hubs in libraries.
Subtitles download is available in the player for videos without subtitles
Volume Buttons can be used to change volume of Remote Players
