Plex for LG TV fubar [fixed: my fault]
Server Version#: last
Player Version#: last
Today I’ve launched Plex on my LG 55C8 and got the new, horrible UI.
No way to revert back to old one but, ok, I can get used to it.
Problem is my Movies, TV programs and Photo tabs are no more: no way to navigate to my contents. No way to reset something and no way to find anything in the settings to make them appear again.
Any way to fix this mess?
Can you post a picture of what you’re seeing? I don’t know if it’s the UNO interface or something else…
My bad, I just had to explore the menu a bit better.
I discovered that, going to “others” I could see all my tabs and pin them to the home page. :slight_smile:
To be honest, now that this new UI is more familiar, I don’t find it “horrible” anymore. I’m starting to like it.
The shock was that, turning TV on, I’ve found everything totally changed and got confused. :slight_smile:
Thanks again for your quick answers.
