Server Version#: 1.15.3.876
Player Version#: 3.83.1
I don’t know the exact reason, but it could happen really often. I can’t imagine any situation when it’s the expected behavior. See attached screenshot. I hope, you can fix it easily. Thank you, Guys.
This often happens if you have both ‘periodic’ and ‘automatic’ library scans activated.
Or have automatic scans activated, but trigger a second scan manually as well.
Settings - Server - Library
You should never do that, particularly if you have automatic library updates activated.
Always download into remporary folder which is not included in a Plex library.
Only when the download has finished, rename and prepare the file according to the guidelines and then move the file into a library path.
Thanks for your reply. I like seeding for long time (support the community), so it’ll cause double disk usage. (I just copy files when renaming is required.)
Do you know why Plex doesn’t filter the exactly same file? It seems easy to develop, and I really can’t imagine any situation when this behavior useful.
