Plex Gives an error when trying to access TV & Movies
Server Version#:1.16.3.1402
I have run Plex as server on my Synology NAS. Now I get an error when it tries to access TV or Movies. The files are in sub directories under a shared file called MEDIA. Plex has r/w premissions to MEDIA. Why can’t it acces them?
The error I get is :- “There was an unexpected error loading this library”
Music and photos are fine.
Logs?
Plex Media Server Logs_2019-08-03_20-28-59.zip (2.0 MB)
Here are the logs.
One thing. When I read your pinned post about permissions I went into file share and Plex already had R/W permissions to MEDIA share. I must have done this in the past when I created the new share. Could this affect anything?
Actually not filesystem related as it turns out.
Aug 03, 2019 14:12:36.528 [0x7fca74437700] ERROR - SQLITE3:(nil), 11, database corruption at line 79051 of [bf8c1b2b7a]
Aug 03, 2019 14:12:36.528 [0x7fca74437700] ERROR - SQLITE3:(nil), 11, statement aborts at 10: [select parents.parent_id,count(*) from metadata_items as parents join metadata_items as leaves on leaves.parent_id=parents.id where parents.metadata_type = 3 group by parents.parent_id
Aug 03, 2019 14:12:36.529 [0x7fca74437700] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: database disk image is malformed
You’ll need to address it first.
https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
Thanks. I have deleted the db file and am now rebuilding.
That has cured the problem. The TV shows are back and the rest are re-building.
Thank You.
