Plex Guide displays wrong channels
The Plex guide says channel 49.1 (Atlanta, GA) is REVN but channel 49.1 is actually METV.
Hi @Nabbster, there are currently several other posts with similar issue.
Check out Issues with Guide layout channels
I think that Plex is incorrectly using the channel id tag in the xmltv format, and this is most likely causing the issue
Yesterday morning the correct station showed up in my guide.
REVN was no longer showing up and METV was.
I even recorded 3 shows from METV, Maverick, Have gun Will Travel and Wagon Train.
This morning METV is gone and REVN is back.
Nabbster, do you want the entire series of have gun with travel i had it on dvd and ripped it to mp4 if your interested in clean set contact me.
Thanks but a little Paladin goes a long way.
:slight_smile:
