@jediobijohn said:
Im using PIA, here are a few of my settings, if anything jumps out to you let me know please
Ok, so PIA are a VPN provider, not a method for connecting. How you connect to a VPN determines how you configure it.
Basically, every type of protocol used in any one VPN is configured differently.
OpenVPN will be configured differently to PPTP, which is different again to IPSec. All are different types of VPN protocol.
One provider (in your case PIA) can provide options for connections using many different types of protocols.
-Connection type UDP
-Remote port Auto
-Request port forwarding (disabled)
-PIA MACE (blocks ads trackers and malware) (disabled)
-VPN Kill Switch (Disabled)
-IPv6 protection (ENABLED) - this is the one that i think might be causing me trouble
Use small packets (disabled)
Enable debug mode (enabled)
Data encryption (aes-128)
Data authentication (sha-1)
Handshake (rsa-2048)
Nothing here is really out of the ordinary, it’s how your applications route through the VPN that seems to be causing the issues. Is the VPN a requirement?
If it’s not, then removing it altogether would resolve the issue.
If it is a requirement, then you may have to force Plex to use a local connection instead of the VPN.
Unfortunately Plex requires at least minimal access to the internet to function properly, so there is no way around it.
I personally cannot really help you with the VPN, and it’s not really Plex’s fault it cannot connect through your VPN either.
Is it possible to maybe talk to your VPN provider?
I hope you can figure it out mate. Maybe post if you find a solution. I imagine others use a VPN as well
