plex.tv down?
I’m getting a unclaimed plex server notice and can’t sign in. Anyone else experiencing this issue on their end?
Bill
My server says its no longer available remotely and that I need to sign back in. But it fails everytime to sign in
You can always check the status of plex.tv services here:
https://status.plex.tv/
…and looking at the site there does seem to have been a couple of blips where plex.tv authentication had issues, but it looks to be fine now
Same issue here. I have no other internet issues on my end.
@mrwes40 said:
Same issue here.
I am still having the issue even though the status page shows all ok.
same issue here. Just installed dvr beta 3. not sure if it is a bad server version or if the issue is with plex.
I was going to upgrade to the newest version (plex pass) and this happened. Never seen this issue before. Now I’m thinking since plex requires a sign in for security and remote access, if it goes down, we’re all in a bind!
Bill
I to was updating when this happened. I am using the Beta Build for DVR and plex web prompted for an update.
Hasn’t worked since.
I tried to reinstall manually the latest beta build as well no luck
has anyone tried to install a build that is not beta to fix yet?
I can hit https://www.plex.tv but not https://plex.tv
Bill
Bill
If you can hit one but not the other I am wondering if you’re having a dns issue.
We’re trying it here and not having any problems signing in. One of the support staff is watching us log in /out and nothing is showing.
Would all of you mind closing the browser and trying again fresh at it? They’re watching it.
If you get any specific errors… please include that in your posts
I was not updating nor do I have a beta version installed and I am having to same issue of an unclaimed media server on my network and then a failed login.
Can you go to Plex.tv directly and hit ‘Launch’ ??
If you get any specific errors.. please include that in your posts
Still the same issue. Here are my screen shots.
I cant even login to plex.tv on another pc now either. Still cant login on server either. Same as mrwes40
May I have your log files please? That will tell me a lot more than a screen shot
tried to close plex server and start it again. still have login issue just like mrwes40.
Are you all using version 1.1.4 ??
Here ya go!
