Hi all,
Has anyone managed to get PHT working on CrunchBang #! Im struggling getting all the dependancies sorted as newer versions need to be installed than those available in the channels :-(
Hi all,
How are you installing? What dependencies do you miss? Can’t you take some packages from Ubuntu?
the main issue came from trying to install a higher version of libc6 than that that was in the channels. I couldnt get the newer version to install as it kept saying it was conflicting with the version installed... is there a way to force the newer version?
