I have an older HTPC that I had downloaded Plex Home Theater on and it works well.
I am unable to find it in the downloads section now.
I only see Plex Media Player.
Is this a replacement for Plex Home Theater?
If I remember correctly, Plex Home Theater has been discontinued. Plex Media Player is sort of a successor but it isn’t a one-by-one replacement.
You should be able to install it on your pc to get an impression and see if it can serve as a replacement for your use case
