Server Version#: 4.116.1
Player Version#: 1.49.0.3994-0d97189b
As per title. I’m sick of having to change the subtitle size for every single episode of a TV show. Either the setting should stick, or you should be able to change the default size.
Change the default here in the settings.
If you change it to something else during playback it will go back to the default afterwards, which I suspect is what’s happening
Doesn’t matter where or when I change the setting. On playback of a new media file it reverts to normal size.
I thought this was a design problem but it sounds like I’m experiencing a bug?
