Subtitles size bug
Server Version#: Windows 1.21.1.3876
Player Version#: Plex for Windows 1.26.0.1531
Changing subtitles size during a playback is working fine. But when starting another video the subtitles size is correctly remembered from the previous change in the selection menu but the actual subtitle size in the video doesn’t match.
I have to change subtitle size and then change back to what it was to get the correct size displayed in the video.
Can you confirm if your issue is similar to this one? Giant subtitles even if tiny or small subtitle size is set as default
Yes seems to be same issue.
I got word that this might be already fixed in the next release.
Definitely, it’ll be in 1.28. Thanks a lot @OttoKerner!
