Which OS are you using? WIndows or is this via a browser ?
for plex unraid. and on my laptop viewing through browser (windows)
Going to teach you something.
Since this is a shell window still on a browser page (right?)
Highlight the text → COPY (control C)
Come to this window
type:
paste the text (control V)
It will look like whta I show to you … Text form is best for me to put into the trouble ticket.
Example:
This:
becomes:
root@dockerplex:/#
root@dockerplex:/# cd /config
root@dockerplex:~# ls
DBRepair.sh Library plexmediaserver_1.29.2.6273-2b1f0cbcd_amd64.deb tmp transcode
root@dockerplex:~# cd /config/Library/Application\ Support/Plex\ Media\ Server/
root@dockerplex:~/Library/Application Support/Plex Media Server#
root@dockerplex:~/Library/Application Support/Plex Media Server# docker stop plex
bash: docker: command not found
root@dockerplex:~/Library/Application Support/Plex Media Server# exit
root@lizum:/home/chuck# docker stop plex
plex
Yes sorry i can do that!
Just how my thought process works.
I thought if i had mounted plex to be off the docker.img it wouldnt of ever go on there though?
Since ive mounted it /mnt/plexcache/appdata/plex/?
root@MediaServer:/tmp# cd music-analysis-input-59ed3d71-4f81-49f8-a183-54d310b94a6e
root@MediaServer:/tmp/music-analysis-input-59ed3d71-4f81-49f8-a183-54d310b94a6e# du -ms .
47864 .
root@MediaServer:/tmp/music-analysis-input-59ed3d71-4f81-49f8-a183-54d310b94a6e# find . -print | wc -l
252
I don’t know how unraid does things.
I don’t have an extra machine to dedicate nor have I been able to get a bootable USB to work (I’m entirely Linux here) to put into a ESXi VM
Not blaming anyone just kinda thought thats how it worked. My fault for assuming
I’m trying to learn more about the files left behind.
when 252 files generates 42 GB of “stuff” … that’s bad.
Using the Highlight-copy
Paste
method, Would you mind getting a ls -la of /tmp/music-analysis-input-59ed3d71-4f81-49f8-a183-54d310b94a6e ?
It’ll look like a lot as you paste the 252 lines but the forum will compact it into a scrollable block of 20 lines
I think that’ll give me what I need for the trouble ticket.
After that, we’ll clean up the space and get you running again
root@MediaServer:/tmp/music-analysis-input-59ed3d71-4f81-49f8-a183-54d310b94a6e# ls -la
total 49012432
drwxr-xr-x 1 abc users 7018 Jan 18 05:24 .
drwxrwxrwt 1 root root 20498 Jan 18 11:06 ..
-rw-r--r-- 1 abc users 3750 Jan 18 05:24 index.txt
-rw-r--r-- 1 abc users 342644240 Jan 18 05:05 track-0000.wav
-rw-r--r-- 1 abc users 219550386 Jan 18 05:05 track-0001.wav
-rw-r--r-- 1 abc users 144705444 Jan 18 05:05 track-0002.wav
-rw-r--r-- 1 abc users 189313596 Jan 18 05:05 track-0003.wav
-rw-r--r-- 1 abc users 105014376 Jan 18 05:05 track-0004.wav
-rw-r--r-- 1 abc users 109365936 Jan 18 05:05 track-0005.wav
-rw-r--r-- 1 abc users 197526190 Jan 18 05:05 track-0006.wav
-rw-r--r-- 1 abc users 199845032 Jan 18 05:05 track-0007.wav
-rw-r--r-- 1 abc users 203447132 Jan 18 05:05 track-0008.wav
-rw-r--r-- 1 abc users 166633074 Jan 18 05:05 track-0009.wav
-rw-r--r-- 1 abc users 221874070 Jan 18 05:05 track-0010.wav
-rw-r--r-- 1 abc users 239094062 Jan 18 05:06 track-0011.wav
-rw-r--r-- 1 abc users 222210702 Jan 18 05:06 track-0012.wav
-rw-r--r-- 1 abc users 172930030 Jan 18 05:06 track-0013.wav
-rw-r--r-- 1 abc users 176512748 Jan 18 05:06 track-0014.wav
-rw-r--r-- 1 abc users 115325998 Jan 18 05:06 track-0015.wav
-rw-r--r-- 1 abc users 156588702 Jan 18 05:06 track-0016.wav
-rw-r--r-- 1 abc users 209270108 Jan 18 05:06 track-0017.wav
-rw-r--r-- 1 abc users 249834708 Jan 18 05:06 track-0018.wav
-rw-r--r-- 1 abc users 257911346 Jan 18 05:06 track-0019.wav
-rw-r--r-- 1 abc users 197621900 Jan 18 05:06 track-0020.wav
-rw-r--r-- 1 abc users 165804756 Jan 18 05:06 track-0021.wav
-rw-r--r-- 1 abc users 239949878 Jan 18 05:06 track-0022.wav
-rw-r--r-- 1 abc users 207414312 Jan 18 05:06 track-0023.wav
-rw-r--r-- 1 abc users 231573276 Jan 18 05:07 track-0024.wav
-rw-r--r-- 1 abc users 266954100 Jan 18 05:07 track-0025.wav
-rw-r--r-- 1 abc users 137281560 Jan 18 05:07 track-0026.wav
-rw-r--r-- 1 abc users 162215218 Jan 18 05:07 track-0027.wav
-rw-r--r-- 1 abc users 440727322 Jan 18 05:07 track-0028.wav
-rw-r--r-- 1 abc users 316010802 Jan 18 05:07 track-0029.wav
-rw-r--r-- 1 abc users 203448704 Jan 18 05:07 track-0030.wav
-rw-r--r-- 1 abc users 379254048 Jan 18 05:07 track-0031.wav
-rw-r--r-- 1 abc users 178198090 Jan 18 05:07 track-0032.wav
-rw-r--r-- 1 abc users 352088364 Jan 18 05:08 track-0033.wav
-rw-r--r-- 1 abc users 166237790 Jan 18 05:08 track-0034.wav
-rw-r--r-- 1 abc users 294213552 Jan 18 05:08 track-0035.wav
-rw-r--r-- 1 abc users 269041606 Jan 18 05:08 track-0036.wav
-rw-r--r-- 1 abc users 393228112 Jan 18 05:08 track-0037.wav
-rw-r--r-- 1 abc users 128452548 Jan 18 05:08 track-0038.wav
-rw-r--r-- 1 abc users 63016218 Jan 18 05:08 track-0039.wav
-rw-r--r-- 1 abc users 100087498 Jan 18 05:08 track-0040.wav
-rw-r--r-- 1 abc users 95527026 Jan 18 05:08 track-0041.wav
-rw-r--r-- 1 abc users 209462356 Jan 18 05:08 track-0042.wav
-rw-r--r-- 1 abc users 119530772 Jan 18 05:08 track-0043.wav
-rw-r--r-- 1 abc users 235958640 Jan 18 05:08 track-0044.wav
-rw-r--r-- 1 abc users 140281798 Jan 18 05:08 track-0045.wav
-rw-r--r-- 1 abc users 148052494 Jan 18 05:08 track-0046.wav
-rw-r--r-- 1 abc users 225491920 Jan 18 05:09 track-0047.wav
-rw-r--r-- 1 abc users 161440434 Jan 18 05:09 track-0048.wav
-rw-r--r-- 1 abc users 160373984 Jan 18 05:09 track-0049.wav
-rw-r--r-- 1 abc users 142207632 Jan 18 05:09 track-0050.wav
-rw-r--r-- 1 abc users 277800162 Jan 18 05:09 track-0051.wav
-rw-r--r-- 1 abc users 202989764 Jan 18 05:09 track-0052.wav
-rw-r--r-- 1 abc users 149661510 Jan 18 05:09 track-0053.wav
-rw-r--r-- 1 abc users 421817340 Jan 18 05:09 track-0054.wav
-rw-r--r-- 1 abc users 16726918 Jan 18 05:09 track-0055.wav
-rw-r--r-- 1 abc users 198326496 Jan 18 05:09 track-0056.wav
-rw-r--r-- 1 abc users 264260754 Jan 18 05:09 track-0057.wav
-rw-r--r-- 1 abc users 184817642 Jan 18 05:09 track-0058.wav
-rw-r--r-- 1 abc users 126727268 Jan 18 05:09 track-0059.wav
-rw-r--r-- 1 abc users 246755790 Jan 18 05:10 track-0060.wav
-rw-r--r-- 1 abc users 216324476 Jan 18 05:10 track-0061.wav
-rw-r--r-- 1 abc users 119180602 Jan 18 05:10 track-0062.wav
-rw-r--r-- 1 abc users 318773756 Jan 18 05:10 track-0063.wav
-rw-r--r-- 1 abc users 130718762 Jan 18 05:10 track-0064.wav
-rw-r--r-- 1 abc users 391224472 Jan 18 05:10 track-0065.wav
-rw-r--r-- 1 abc users 176904096 Jan 18 05:10 track-0066.wav
-rw-r--r-- 1 abc users 162714220 Jan 18 05:10 track-0067.wav
-rw-r--r-- 1 abc users 103793968 Jan 18 05:10 track-0068.wav
-rw-r--r-- 1 abc users 207797244 Jan 18 05:10 track-0069.wav
-rw-r--r-- 1 abc users 181045322 Jan 18 05:10 track-0070.wav
-rw-r--r-- 1 abc users 174517722 Jan 18 05:10 track-0071.wav
-rw-r--r-- 1 abc users 198327280 Jan 18 05:10 track-0072.wav
-rw-r--r-- 1 abc users 194461866 Jan 18 05:11 track-0073.wav
-rw-r--r-- 1 abc users 176555614 Jan 18 05:11 track-0074.wav
-rw-r--r-- 1 abc users 186662422 Jan 18 05:11 track-0075.wav
-rw-r--r-- 1 abc users 330908024 Jan 18 05:11 track-0076.wav
-rw-r--r-- 1 abc users 156919862 Jan 18 05:11 track-0077.wav
-rw-r--r-- 1 abc users 283523052 Jan 18 05:11 track-0078.wav
-rw-r--r-- 1 abc users 208310456 Jan 18 05:11 track-0079.wav
-rw-r--r-- 1 abc users 151089568 Jan 18 05:11 track-0080.wav
-rw-r--r-- 1 abc users 177345328 Jan 18 05:11 track-0081.wav
-rw-r--r-- 1 abc users 242151884 Jan 18 05:11 track-0082.wav
-rw-r--r-- 1 abc users 178102122 Jan 18 05:11 track-0083.wav
-rw-r--r-- 1 abc users 136473336 Jan 18 05:11 track-0084.wav
-rw-r--r-- 1 abc users 139766662 Jan 18 05:11 track-0085.wav
-rw-r--r-- 1 abc users 335452566 Jan 18 05:12 track-0086.wav
-rw-r--r-- 1 abc users 349575690 Jan 18 05:12 track-0087.wav
-rw-r--r-- 1 abc users 338065822 Jan 18 05:12 track-0088.wav
-rw-r--r-- 1 abc users 363104932 Jan 18 05:12 track-0089.wav
-rw-r--r-- 1 abc users 381424750 Jan 18 05:12 track-0090.wav
-rw-r--r-- 1 abc users 175539728 Jan 18 05:12 track-0091.wav
-rw-r--r-- 1 abc users 163061594 Jan 18 05:12 track-0092.wav
-rw-r--r-- 1 abc users 128162610 Jan 18 05:12 track-0093.wav
-rw-r--r-- 1 abc users 227959626 Jan 18 05:12 track-0094.wav
-rw-r--r-- 1 abc users 256006234 Jan 18 05:12 track-0095.wav
-rw-r--r-- 1 abc users 276055780 Jan 18 05:13 track-0096.wav
-rw-r--r-- 1 abc users 246470898 Jan 18 05:13 track-0097.wav
-rw-r--r-- 1 abc users 303285826 Jan 18 05:13 track-0098.wav
-rw-r--r-- 1 abc users 353339596 Jan 18 05:13 track-0099.wav
-rw-r--r-- 1 abc users 396866872 Jan 18 05:13 track-0100.wav
-rw-r--r-- 1 abc users 182198064 Jan 18 05:13 track-0101.wav
-rw-r--r-- 1 abc users 183160144 Jan 18 05:13 track-0102.wav
-rw-r--r-- 1 abc users 164790048 Jan 18 05:13 track-0103.wav
-rw-r--r-- 1 abc users 113910270 Jan 18 05:13 track-0104.wav
-rw-r--r-- 1 abc users 291898200 Jan 18 05:14 track-0105.wav
-rw-r--r-- 1 abc users 244316556 Jan 18 05:14 track-0106.wav
-rw-r--r-- 1 abc users 378680760 Jan 18 05:14 track-0107.wav
-rw-r--r-- 1 abc users 281117998 Jan 18 05:14 track-0108.wav
-rw-r--r-- 1 abc users 79643578 Jan 18 05:14 track-0109.wav
-rw-r--r-- 1 abc users 133699720 Jan 18 05:14 track-0110.wav
-rw-r--r-- 1 abc users 254536696 Jan 18 05:14 track-0111.wav
-rw-r--r-- 1 abc users 193230580 Jan 18 05:14 track-0112.wav
-rw-r--r-- 1 abc users 131167058 Jan 18 05:14 track-0113.wav
-rw-r--r-- 1 abc users 80364558 Jan 18 05:14 track-0114.wav
-rw-r--r-- 1 abc users 142274542 Jan 18 05:14 track-0115.wav
-rw-r--r-- 1 abc users 146637224 Jan 18 05:14 track-0116.wav
-rw-r--r-- 1 abc users 236872190 Jan 18 05:14 track-0117.wav
-rw-r--r-- 1 abc users 154119506 Jan 18 05:14 track-0118.wav
-rw-r--r-- 1 abc users 203286588 Jan 18 05:14 track-0119.wav
-rw-r--r-- 1 abc users 139368756 Jan 18 05:14 track-0120.wav
-rw-r--r-- 1 abc users 153810046 Jan 18 05:15 track-0121.wav
-rw-r--r-- 1 abc users 153065192 Jan 18 05:15 track-0122.wav
-rw-r--r-- 1 abc users 130040712 Jan 18 05:15 track-0123.wav
-rw-r--r-- 1 abc users 155877320 Jan 18 05:15 track-0124.wav
-rw-r--r-- 1 abc users 230274510 Jan 18 05:15 track-0125.wav
-rw-r--r-- 1 abc users 130284794 Jan 18 05:15 track-0126.wav
-rw-r--r-- 1 abc users 171481432 Jan 18 05:15 track-0127.wav
-rw-r--r-- 1 abc users 135048632 Jan 18 05:15 track-0128.wav
-rw-r--r-- 1 abc users 146369698 Jan 18 05:15 track-0129.wav
-rw-r--r-- 1 abc users 166087186 Jan 18 05:15 track-0130.wav
-rw-r--r-- 1 abc users 116088524 Jan 18 05:15 track-0131.wav
-rw-r--r-- 1 abc users 165312270 Jan 18 05:15 track-0132.wav
-rw-r--r-- 1 abc users 209014286 Jan 18 05:15 track-0133.wav
-rw-r--r-- 1 abc users 221776908 Jan 18 05:15 track-0134.wav
-rw-r--r-- 1 abc users 191085560 Jan 18 05:16 track-0135.wav
-rw-r--r-- 1 abc users 170351986 Jan 18 05:16 track-0136.wav
-rw-r--r-- 1 abc users 187243612 Jan 18 05:16 track-0137.wav
-rw-r--r-- 1 abc users 138422762 Jan 18 05:16 track-0138.wav
-rw-r--r-- 1 abc users 93159158 Jan 18 05:16 track-0139.wav
-rw-r--r-- 1 abc users 417056932 Jan 18 05:16 track-0140.wav
-rw-r--r-- 1 abc users 130660972 Jan 18 05:16 track-0141.wav
-rw-r--r-- 1 abc users 274141382 Jan 18 05:16 track-0142.wav
-rw-r--r-- 1 abc users 158888296 Jan 18 05:16 track-0143.wav
-rw-r--r-- 1 abc users 145380628 Jan 18 05:16 track-0144.wav
-rw-r--r-- 1 abc users 165318462 Jan 18 05:16 track-0145.wav
-rw-r--r-- 1 abc users 165477774 Jan 18 05:16 track-0146.wav
-rw-r--r-- 1 abc users 153840194 Jan 18 05:16 track-0147.wav
-rw-r--r-- 1 abc users 234848278 Jan 18 05:16 track-0148.wav
-rw-r--r-- 1 abc users 123777130 Jan 18 05:16 track-0149.wav
-rw-r--r-- 1 abc users 225137694 Jan 18 05:17 track-0150.wav
-rw-r--r-- 1 abc users 207406592 Jan 18 05:17 track-0151.wav
-rw-r--r-- 1 abc users 253574522 Jan 18 05:17 track-0152.wav
-rw-r--r-- 1 abc users 174267708 Jan 18 05:17 track-0153.wav
-rw-r--r-- 1 abc users 134762282 Jan 18 05:17 track-0154.wav
-rw-r--r-- 1 abc users 61832476 Jan 18 05:17 track-0155.wav
-rw-r--r-- 1 abc users 222632400 Jan 18 05:17 track-0156.wav
-rw-r--r-- 1 abc users 151782960 Jan 18 05:17 track-0157.wav
-rw-r--r-- 1 abc users 140546498 Jan 18 05:17 track-0158.wav
-rw-r--r-- 1 abc users 157493524 Jan 18 05:17 track-0159.wav
-rw-r--r-- 1 abc users 165651694 Jan 18 05:17 track-0160.wav
-rw-r--r-- 1 abc users 386141976 Jan 18 05:17 track-0161.wav
-rw-r--r-- 1 abc users 157080400 Jan 18 05:17 track-0162.wav
-rw-r--r-- 1 abc users 224130968 Jan 18 05:18 track-0163.wav
-rw-r--r-- 1 abc users 120359104 Jan 18 05:18 track-0164.wav
-rw-r--r-- 1 abc users 178707034 Jan 18 05:18 track-0165.wav
-rw-r--r-- 1 abc users 124274712 Jan 18 05:18 track-0166.wav
-rw-r--r-- 1 abc users 180981128 Jan 18 05:18 track-0167.wav
-rw-r--r-- 1 abc users 234924226 Jan 18 05:18 track-0168.wav
-rw-r--r-- 1 abc users 174722346 Jan 18 05:18 track-0169.wav
-rw-r--r-- 1 abc users 231478296 Jan 18 05:18 track-0170.wav
-rw-r--r-- 1 abc users 160416826 Jan 18 05:18 track-0171.wav
-rw-r--r-- 1 abc users 186551524 Jan 18 05:18 track-0172.wav
-rw-r--r-- 1 abc users 149989072 Jan 18 05:18 track-0173.wav
-rw-r--r-- 1 abc users 168569230 Jan 18 05:18 track-0174.wav
-rw-r--r-- 1 abc users 136583684 Jan 18 05:18 track-0175.wav
-rw-r--r-- 1 abc users 199601672 Jan 18 05:18 track-0176.wav
-rw-r--r-- 1 abc users 277942806 Jan 18 05:19 track-0177.wav
-rw-r--r-- 1 abc users 128629214 Jan 18 05:19 track-0178.wav
-rw-r--r-- 1 abc users 168437290 Jan 18 05:19 track-0179.wav
-rw-r--r-- 1 abc users 160557606 Jan 18 05:19 track-0180.wav
-rw-r--r-- 1 abc users 200070802 Jan 18 05:19 track-0181.wav
-rw-r--r-- 1 abc users 169400882 Jan 18 05:19 track-0182.wav
-rw-r--r-- 1 abc users 207326688 Jan 18 05:19 track-0183.wav
-rw-r--r-- 1 abc users 110787968 Jan 18 05:19 track-0184.wav
-rw-r--r-- 1 abc users 150593432 Jan 18 05:19 track-0185.wav
-rw-r--r-- 1 abc users 221591504 Jan 18 05:19 track-0186.wav
-rw-r--r-- 1 abc users 184234406 Jan 18 05:19 track-0187.wav
-rw-r--r-- 1 abc users 293543188 Jan 18 05:19 track-0188.wav
-rw-r--r-- 1 abc users 146701532 Jan 18 05:19 track-0189.wav
-rw-r--r-- 1 abc users 190322212 Jan 18 05:19 track-0190.wav
-rw-r--r-- 1 abc users 178283230 Jan 18 05:20 track-0191.wav
-rw-r--r-- 1 abc users 329460688 Jan 18 05:20 track-0192.wav
-rw-r--r-- 1 abc users 223002634 Jan 18 05:20 track-0193.wav
-rw-r--r-- 1 abc users 201205978 Jan 18 05:20 track-0194.wav
-rw-r--r-- 1 abc users 138002954 Jan 18 05:20 track-0195.wav
-rw-r--r-- 1 abc users 212545042 Jan 18 05:20 track-0196.wav
-rw-r--r-- 1 abc users 383030102 Jan 18 05:20 track-0197.wav
-rw-r--r-- 1 abc users 247028288 Jan 18 05:20 track-0198.wav
-rw-r--r-- 1 abc users 214287082 Jan 18 05:20 track-0199.wav
-rw-r--r-- 1 abc users 175545604 Jan 18 05:20 track-0200.wav
-rw-r--r-- 1 abc users 240580014 Jan 18 05:20 track-0201.wav
-rw-r--r-- 1 abc users 171431180 Jan 18 05:20 track-0202.wav
-rw-r--r-- 1 abc users 212102976 Jan 18 05:21 track-0203.wav
-rw-r--r-- 1 abc users 152516198 Jan 18 05:21 track-0204.wav
-rw-r--r-- 1 abc users 184770984 Jan 18 05:21 track-0205.wav
-rw-r--r-- 1 abc users 166864594 Jan 18 05:21 track-0206.wav
-rw-r--r-- 1 abc users 179617612 Jan 18 05:21 track-0207.wav
-rw-r--r-- 1 abc users 253191648 Jan 18 05:21 track-0208.wav
-rw-r--r-- 1 abc users 261371030 Jan 18 05:21 track-0209.wav
-rw-r--r-- 1 abc users 171524130 Jan 18 05:21 track-0210.wav
-rw-r--r-- 1 abc users 343606262 Jan 18 05:21 track-0211.wav
-rw-r--r-- 1 abc users 113154372 Jan 18 05:21 track-0212.wav
-rw-r--r-- 1 abc users 267015272 Jan 18 05:21 track-0213.wav
-rw-r--r-- 1 abc users 193909400 Jan 18 05:21 track-0214.wav
-rw-r--r-- 1 abc users 300747058 Jan 18 05:22 track-0215.wav
-rw-r--r-- 1 abc users 168928482 Jan 18 05:22 track-0216.wav
-rw-r--r-- 1 abc users 234210336 Jan 18 05:22 track-0217.wav
-rw-r--r-- 1 abc users 174092822 Jan 18 05:22 track-0218.wav
-rw-r--r-- 1 abc users 188412168 Jan 18 05:22 track-0219.wav
-rw-r--r-- 1 abc users 123790164 Jan 18 05:22 track-0220.wav
-rw-r--r-- 1 abc users 222262800 Jan 18 05:22 track-0221.wav
-rw-r--r-- 1 abc users 191414836 Jan 18 05:22 track-0222.wav
-rw-r--r-- 1 abc users 122252492 Jan 18 05:22 track-0223.wav
-rw-r--r-- 1 abc users 125429380 Jan 18 05:22 track-0224.wav
-rw-r--r-- 1 abc users 323974870 Jan 18 05:22 track-0225.wav
-rw-r--r-- 1 abc users 148043948 Jan 18 05:22 track-0226.wav
-rw-r--r-- 1 abc users 152527082 Jan 18 05:22 track-0227.wav
-rw-r--r-- 1 abc users 159894838 Jan 18 05:23 track-0228.wav
-rw-r--r-- 1 abc users 181280970 Jan 18 05:23 track-0229.wav
-rw-r--r-- 1 abc users 145036258 Jan 18 05:23 track-0230.wav
-rw-r--r-- 1 abc users 221103128 Jan 18 05:23 track-0231.wav
-rw-r--r-- 1 abc users 270198700 Jan 18 05:23 track-0232.wav
-rw-r--r-- 1 abc users 161526634 Jan 18 05:23 track-0233.wav
-rw-r--r-- 1 abc users 193692528 Jan 18 05:23 track-0234.wav
-rw-r--r-- 1 abc users 199772516 Jan 18 05:23 track-0235.wav
-rw-r--r-- 1 abc users 177603836 Jan 18 05:23 track-0236.wav
-rw-r--r-- 1 abc users 179838848 Jan 18 05:23 track-0237.wav
-rw-r--r-- 1 abc users 129398710 Jan 18 05:23 track-0238.wav
-rw-r--r-- 1 abc users 103862556 Jan 18 05:23 track-0239.wav
-rw-r--r-- 1 abc users 386946042 Jan 18 05:24 track-0240.wav
-rw-r--r-- 1 abc users 258614252 Jan 18 05:23 track-0241.wav
-rw-r--r-- 1 abc users 214233626 Jan 18 05:24 track-0242.wav
-rw-r--r-- 1 abc users 176252776 Jan 18 05:24 track-0243.wav
-rw-r--r-- 1 abc users 218096368 Jan 18 05:24 track-0244.wav
-rw-r--r-- 1 abc users 200012058 Jan 18 05:24 track-0245.wav
-rw-r--r-- 1 abc users 203325930 Jan 18 05:24 track-0246.wav
-rw-r--r-- 1 abc users 195046686 Jan 18 05:24 track-0247.wav
-rw-r--r-- 1 abc users 210902852 Jan 18 05:24 track-0248.wav
-rw-r--r-- 1 abc users 263637950 Jan 18 05:24 track-0249.wav
is it better i just turn off the sonic analyser then if it makes this many files or am i just in an abnormal situation?
Just what I expected. THANK YOU!
Now, you get this cleaned up
cd /tmp
rm -rf music-analysis-input-59ed3d71-4f81-49f8-a183-54d310b94a6e
df -h . # this should be back to normal usage
root@MediaServer:/tmp# rm -rf music-analysis-input-59ed3d71-4f81-49f8-a183-54d310b94a6e
root@MediaServer:/tmp# df -h .
Filesystem Size Used Avail Use% Mounted on
/dev/loop2 100G 44G 55G 45% /
Yea it has thank you! again. now to avoid this is there any way to redirect these files off the docker.img like in my appdata thats off the docker.img? and still keep the sonic analyser running or is this an abnormal situation? Where should i go from here, since i dont like my docker.img fillling up like that
Im gonna bet this is not normal, and chuck is going to look into it ![]()
No you can’t redirect them anywhere. A container is an encapsulation.
The only thing you could do (on Linux workstations at least) is move the entire container to bigger storage.
I don’t know unraid so can’t advise you there. I do see what looks like storage quotas . Are those ZFS quotas ? Can you increase the quota for now - OR – go in every day and clean it out until it’s fixed ?
So its an issue that doesnt normally happen? then is what your saying? Yes i do have an raid like storage setup which is what unraid is about sort of creates an array of drives and shares it across all the disks. In the past i had to increase my docker.img size which isnt an issue just was told from others i spoke to that you shouldnt need too for this amount of size. I guess il leave it off for now sonic since its just been constant issues atm.
Also thank you for your patients since im still learning linux myself and unraid was ment to be the cross for me to start learning the platform
How much storage is allocated to the container? 64 GB ?
Also bet you have a lot of music ???
I didnt think i had that much music. I mean a decent amount i couldnt tell you an exact number of the top of my head id have to look. also not sure about the amount allocated to plex spacifically since the docker.img size is capped at 100gb and is shared across each of my running containers within the docker. I mean maybe but it doesnt seem so it just fills untill its full each of the containers i dont think theres a cap for any of them specifically.
I can also adjust the 100gb cappedd for docker.img but didnt think i needed to.
You have 100 GB for all containers ?
Plex has 42 GB in /tmp for music analysis.
I think you’ll need more. 100 GB for Plex isn’t that big a deal.
Please go to your Plex/web interface and see how many “tracks” are defined.
Yea i have 100gb shared across each of my containers yes and just keeps filling untill its full. Since im pretty sure the purpose for docker.img in unraid is to hold the image and move the configuration files off the docker.img into another appdata folder which is the app data folder i keep mentioning. but it seems for this sonic analyser it has been set to stay on the docker.img.
3117 tracks.
Before today plex only uses around 2 to 3 gb and same for most other containers. Which is why its at 100gb capped. Most of the appdata is stored outside
What are they? 260MB for an audio track is huge
there high quality version of my music. wav and flac files. theres also podcasts in there also forgot to mention
