Plex is grouping all NFL recordings into the same object?
I’m recording up to 3 NFL games per day, but I can only view the 1st one that recorded.
The other 2 are in the folder in the Plex directory, but not viewable via the plex player.
Is this something I have to fix in the DVR settings or the library settings? I’m using the default TV shows settings.
I can paste screen shots if needed.
This is a known issue, one work around described here:
Thank you so much!
The DVR doesn’t give me the option to select this new “other videos” library I created, I can only select on the drop down menu the two TV Shows libraries I created. Something I can do to fix that?
