Plex îs not letting me Match
Im running my plex on a Synology server and for years I’ve never had any problems until yesterday when it stopped matching my movies. is there anyone else out there having this problem?
Can you stop the server,
Using FileStation,
Make a ZIP file of the “Logs” folder (Underneath “Plex Media Server” folder)
Download it
and attach it?
Or just attach the server-generated logs ZIP file ?
Does it say “Not Authorized”?
Im sorry but Im not the most tech savvy person so when I try to do what you asked im having issues. Also, I just tried to match them again and I was able to do two of them but then it stopped.
Plex Media Server Logs_2024-06-11_10-52-39.zip (5.5 MB)
Let me know if this helps, I was able to match three movies but now its not letting me anymore
@dlhei
Either your synology is misconfigured or it’s not connected correctly to the modem / router.
Jun 09, 2024 05:07:32.992 [140562840275768] DEBUG - [EventSourceClient/pubsub/45.33.119.35:443] Resolved 45.33.119.35 to 45.33.119.35:443
Jun 09, 2024 05:07:39.113 [140562809383736] DEBUG - [HttpClient/HCl#4bcc] HTTP simulating 408 after curl timeout
Jun 09, 2024 05:07:39.113 [140562695490360] WARN - [EventSourceClient/pubsub/45.33.119.35:443] MyPlex: Updating device connections failed, retrying in 160 seconds.
Jun 09, 2024 05:07:52.993 [140562840275768] DEBUG - [EventSourceClient/pubsub/45.33.119.35:443] Failure: 125 - Operation canceled.
Jun 09, 2024 05:07:52.994 [140562840275768] DEBUG - [EventSourceClient/pubsub/45.33.119.35:443/PubsubServerManager/getNextWorkingHost/dfw] 0 total hosts available in region, starting tests
Jun 09, 2024 05:07:52.994 [140562840275768] DEBUG - [EventSourceClient/pubsub/45.33.119.35:443/PubsubServerManager/getNextWorkingHost/dfw] No working hosts in region, refreshing full host list
Jun 09, 2024 05:07:57.993 [140562840275768] WARN - [EventSourceClient/pubsub/45.33.119.35:443/PubsubServerManager/getNextWorkingHost/dfw/process] Connection to 45.33.119.35 failed: Operation timed out.
Jun 09, 2024 05:07:57.993 [140562840275768] ERROR - [EventSourceClient/pubsub/45.33.119.35:443] Retrying in 120 seconds.
What I’m seeing looks like the IP address of the Default Gateway is wrong.
( Syno: Control Panel- Network - Network Interface - Default Gateway)
