Plex not matching movies/tv shows anymore
Server Version#: 1.25.6.5577
It appears that my Plex server stopped matching any media files over the weekend and does not import any meta data anymore. When I add a file to my library, I get nothing; a manual matching attempt just gives me a “No matches found.” message.
It appears to me that the search never makes it to the internet since that message comes up almost immediately. I do not use a VPN, and while I have a firewall on my PC, that shoudl not affect the Synology box. As far as I know, nothing in my setup has changed; it just stopped working. This started with version 1.25.5.5492 installed; upgrading to version 1.25.6.5577 did not fix it.
Any suggestions what happened/how to solve it?
Would you please attempt a rescan.
after it completes, download the DEBUG logs ZIP file and attach it.
We’ll see if there are any obvious errors in the logs
Here you go. Thanks for your help.
Plex Media Server Logs_2022-03-08_21-34-01.zip (5.7 MB)
@ChuckPa – did those logs help at all?
