Plex is not using local metadata for Album Artist and Artist
Server Version#: 1.41.3.9314
Player Version#: 1.105.2.269-12a32491
For my music library, I have the following set:
Scanner: Plex Music
Agent: Plex Music
Prefer local metadata: Checked
Genres: Embedded Tags
Album Art: Local Files Only
For my Plex server, the following settings are set under the Agents (Legacy) section:
Artists:
  1. Local Media Assets (Artists)
  2. Personal Media Artists
    Albums:
  3. Local Media Assets (Albums)
  4. Personal Media Albums
With certain albums, Plex will use a value for Album Artist and Artist that is not embedded in my tags. For example I will use the Album Eve by The Alan Parsons Project.The first track in this album has these tags:
mediainfo -f output
General
Count : 373
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Count of audio streams : 1
Audio_Format_List : FLAC
Audio_Format_WithHint_List : FLAC
Audio codecs : FLAC
Audio_Language_List : zxx
Audio_Channels_Total : 2
Complete name : 1-01 Lucifer.flac
File name extension : 1-01 Lucifer.flac
File name : 1-01 Lucifer
File extension : flac
Format : FLAC
Format : FLAC
Format/Info : Free Lossless Audio Codec
Format/Url : FLAC - What is FLAC?
Format/Extensions usually used : fla flac
Commercial name : FLAC
Internet media type : audio/x-flac
File size : 36320686
File size : 34.6 MiB
File size : 35 MiB
File size : 35 MiB
File size : 34.64 MiB
Duration : 308520
Duration : 5 min 8 s
Duration : 5 min 8 s 520 ms
Duration : 00:05:08.520
Overall bit rate mode : VBR
Overall bit rate mode : Variable
Overall bit rate : 941804
Overall bit rate : 942 kb/s
Stream size : 0
Stream size : 0.00 Byte (0%)
Stream size : Byte0
Stream size : 0.0 Byte
Stream size : 0.000 Byte
Proportion of this stream : 0.00000
Album replay gain : -7.20
Album replay gain : -7.20 dB
Album replay gain peak : 1.000000
Title : Lucifer
Album : Eve
Part : 1
Part/Total : 1
Track name : Lucifer
Track name/Position : 1
Track name/Total : 9
Performer : Andrew Powell (chorus master);Ian Bairnson (acoustic guitar and electric guitar);BJ Cole (steel guitar);Stuart Elliott (drums (drum set) and percussion);Duncan Mackay (keyboard);Eric Woolfson (keyboard);Alan Parsons (additional);Eric Woolfson (additional);David Paton (bass guitar);Stuart Tosh (drums (drum set));Stuart Elliott (drums (drum set));Orchestra of the Munich Chamber Opera (orchestra);David Paton (background vocals);Chris Rainbow (background vocals);Ian Bairnson (electric guitar);Ian Bairnson (acoustic guitar);Stuart Elliott (percussion)
Composer : Test / The Alan Parsons Project
Conductor : Andrew Powell
Label : Arista
Genre : Pop;Pop Rock;Progressive Rock;Rock
Recorded date : 1990-10
File last modification date : 2025-01-05 18:03:44 UTC
File last modification date (local) : 2025-01-05 12:03:44
ISRC : USAR19700011
Cover : Yes
Cover type : Cover (front)
Cover MIME : image/jpeg
MUSICBRAINZ_RELEASEGROUPID : 5e8f11c2-e08c-3e36-a3e6-d6954b1bf88f
ORIGINALDATE : 1979-08-27
ORIGINALYEAR : 1979
RELEASETYPE : album
BARCODE : 078221806220
ENGINEER : Patrick Jauneaud / Dave Siddle / Alan Parsons
ARRANGER : Andrew Powell
PRODUCER : Test
ASIN : B000002VCB
RELEASESTATUS : official
CATALOGNUMBER : ARCD 8062
RELEASECOUNTRY : US
ALBUMARTISTSORT : Parsons, Alan, Project, The
SCRIPT : Latn
MEDIA : CD
ARTISTS : The Alan Parsons Project
MUSICBRAINZ_WORKID : d1fdd296-f032-36c3-ba12-1b0a041d7e04
WORK : Lucifer
COMPOSERSORT : Test
MUSICBRAINZ_RELEASETRACKID : 67122fcc-44ce-3718-a729-77b56a3f3c1e
ACOUSTID_ID : 7f484a95-162a-447f-a91d-b8ed48805cd2
WRITER : Test
Album/Composer : The Alan Parsons Project
Audio
Count : 286
Kind of stream : Audio
Format : FLAC
Format : FLAC
Duration : 308520
Bit rate mode : VBR
Bit rate mode : Variable
Bit rate : 930807
Bit rate : 931 kb/s
Channel(s) : 2
Channel(s) : 2 channels
Channel positions : Front: L R
Channel positions : 2/0/0
Channel layout : L R
Sampling rate : 44100
Sampling rate : 44.1 kHz
Samples count : 13605732
Bit depth : 16
Bit depth : 16 bits
Compression mode : Lossless
Replay gain : -7.17
Replay gain : -7.17 dB
Replay gain peak : 1.000000
Stream size : 35896569
Stream size : 34.2 MiB (99%)
Stream size : 34 MiB
Stream size : 34.23 MiB
Proportion of this stream : 0.98832
Writing library : reference libFLAC 1.3.1 20141125
Writing library : libFLAC 1.3.1 (2014-11-25)
Encoded_Library_Name : libFLAC
Encoded_Library_Version : 1.3.1
Encoded_Library_Date : 2014-11-25
Language : zxx
Language : zxx
Language : zxx
Language : zxx
MD5 of the unencoded content : 0E988793F99BA852DF58F9E1C4FFA39C
ffprobe output
ffprobe version 6.1.1 Copyright (c) 2007-2023 the FFmpeg developers
built with gcc 13 (GCC)
configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --docdir=/usr/share/doc/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags=‘-O2 -flto=auto -ffat-lto-objects -fexceptions -g -grecord-gcc-switches -pipe -Wall -Werror=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer ’ --extra-ldflags=’-Wl,-z,relro -Wl,–as-needed -Wl,-z,now -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -Wl,–build-id=sha1 -specs=/usr/lib/rpm/redhat/redhat-package-notes ’ --disable-htmlpages --enable-pic --disable-stripping --enable-shared --disable-static --enable-gpl --enable-version3 --enable-libsmbclient --disable-openssl --enable-bzlib --enable-frei0r --enable-chromaprint --enable-gcrypt --enable-gnutls --enable-ladspa --enable-lcms2 --enable-libshaderc --enable-vulkan --disable-cuda-sdk --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libdc1394 --enable-libdrm --enable-libfdk-aac --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libiec61883 --enable-libilbc --enable-libjack --enable-libjxl --enable-libmodplug --enable-libmp3lame --enable-libmysofa --enable-libopenh264-dlopen --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libplacebo --enable-libpulse --enable-librabbitmq --enable-librav1e --enable-librist --enable-librsvg --enable-librubberband --enable-libsnappy --enable-libsvtav1 --enable-libsoxr --enable-libspeex --enable-libssh --enable-libsrt --enable-libtesseract --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libv4l2 --enable-libvpx --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lto --enable-libvpl --enable-lv2 --enable-vaapi --enable-vdpau --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libxvid --enable-openal --enable-opencl --enable-opengl --enable-pthreads --enable-vapoursynth --enable-muxers --enable-demuxers --enable-hwaccels --disable-encoders --disable-decoders --disable-decoder=‘h264,hevc,vc1’ --enable-encoder=‘,a64multi,a64multi5,aac,libfdk_aac,ac3,adpcm_adx,adpcm_argo,adpcm_g722,adpcm_g726,adpcm_g726le,adpcm_ima_alp,adpcm_ima_amv,adpcm_ima_apm,adpcm_ima_qt,adpcm_ima_ssi,adpcm_ima_wav,adpcm_ima_ws,adpcm_ms,adpcm_swf,adpcm_yamaha,alac,alias_pix,amv,anull,apng,ass,asv1,asv2,av1_amf,av1_nvenc,av1_qsv,av1_vaapi,ayuv,bitpacked,bmp,cinepak,cljr,dca,dfpwm,dnxhd,dpx,dvbsub,dvdsub,dvvideo,exr,ffv1,ffvhuff,flac,flashsv,flashsv2,flv,g723_1,gif,h261,h263,h263_v4l2m2m,h263p,h264_amf,h264_nvenc,h264_qsv,h264_v4l2m2m,h264_vaapi,hap,hdr,hevc_amf,hevc_nvenc,hevc_qsv,hevc_v4l2m2m,hevc_vaapi,huffyuv,ilbc,jpegls,jpeg2000,libaom,libaom_av1,libcodec2,libgsm,libgsm_ms,libilbc,libjxl,libmp3lame,libopencore_amrnb,libopenh264,libopenjpeg,libopus,librav1e,libschroedinger,libspeex,libsvtav1,libtheora,libtwolame,libvo_amrwbenc,libvorbis,libvpx_vp8,libvpx_vp9,libwebp,libwebp_anim,libxvid,mjpeg,mjpeg_qsv,mjpeg_vaapi,mlp,mp2,mp2fixed,mpeg1video,mpeg2video,mpeg2_qsv,mpeg2_vaapi,mpeg4,mpeg4_v4l2m2m,msmpeg4v2,msmpeg4v3,msvideo1,nellymoser,opus,pam,pbm,pcm_alaw,pcm_f32be,pcm_f32le,pcm_f64be,pcm_f64le,pcm_mulaw,pcm_s16be,pcm_s16be_planar,pcm_s16le,pcm_s16le_planar,pcm_s24be,pcm_s24le,pcm_s24le_planar,pcm_s32be,pcm_s32le,pcm_s32le_planar,pcm_s8,pcm_s8_planar,pcm_u16be,pcm_u16le,pcm_u24be,pcm_u24le,pcm_u32be,pcm_u32le,pcm_u8,pcx,pgm,pgmyuv,phm,png,ppm,qoi,qtrle,r10k,r210,ra_144,rawvideo,roq,roq_dpcm,rpza,rv10,rv20,s302m,sbc,sgi,smc,snow,sonic,sonic_ls,speedhq,srt,ssa,subrip,sunrast,svq1,targa,text,tiff,truehd,tta,ttml,utvideo,v210,v308,v408,v410,vc1_qsv,vc1_v4l2m2m,vc2,vnull,vorbis,vp8_qsv,vp8_v4l2m2m,vp8_vaapi,vp9_qsv,vp9_vaapi,wavpack,wbmp,webvtt,wmav1,wmav2,wmv1,wmv2,wrapped_avframe,xbm,xface,xsub,xwd,y41p,yuv4,zlib,zmbv,’ --enable-decoder=‘,aasc,libfdk_aac,ac3,acelp_kelvin,adpcm_4xm,adpcm_adx,adpcm_afc,adpcm_agm,adpcm_aica,adpcm_argo,adpcm_ct,adpcm_dtk,adpcm_ea,adpcm_ea_maxis_xa,adpcm_ea_r1,adpcm_ea_r2,adpcm_ea_r3,adpcm_ea_xas,adpcm_g722,adpcm_g726,adpcm_g726le,adpcm_ima_acorn,adpcm_ima_alp,adpcm_ima_amv,adpcm_ima_apc,adpcm_ima_apm,adpcm_ima_cunning,adpcm_ima_dat4,adpcm_ima_dk3,adpcm_ima_dk4,adpcm_ima_ea_eacs,adpcm_ima_ea_sead,adpcm_ima_iss,adpcm_ima_moflex,adpcm_ima_mtf,adpcm_ima_oki,adpcm_ima_qt,adpcm_ima_qt_at,adpcm_ima_rad,adpcm_ima_smjpeg,adpcm_ima_ssi,adpcm_ima_wav,adpcm_ima_ws,adpcm_ms,adpcm_mtaf,adpcm_psx,adpcm_sbpro_2,adpcm_sbpro_3,adpcm_sbpro_4,adpcm_swf,adpcm_thp,adpcm_thp_le,adpcm_vima,adpcm_xa,adpcm_xmd,adpcm_yamaha,adpcm_zork,alac,alias_pix,amrnb,amrwb,amv,anm,ansi,anull,apac,ape,apng,arbc,argo,ass,asv1,asv2,atrac1,atrac3,atrac3al,atrac3p,atrac3pal,aura,aura2,av1,av1_qsv,ayuv,bethsoftvid,bfi,bink,binkaudio_dct,binkaudio_rdft,bintext,bitpacked,bmp,bmv_audio,bmv_video,bonk,brender_pix,c93,cbd2_dpcm,ccaption,cdgraphics,cdtoons,cdxl,cinepak,clearvideo,cljr,cook,cpia,cscd,cyuv,dca,dds,derf_dpcm,dfa,dfpwm,dirac,dnxhd,dolby_e,dpx,dsd_lsbf,dsd_msbf,dsicinaudio,dsicinvideo,dss_sp,dvaudio,dvbsub,dvdsub,dvvideo,dxa,dxtory,eacmv,eamad,eatgq,eatgv,eatqi,eightbps,eightsvx_exp,eightsvx_fib,escape124,escape130,evrc,exr,ffv1,ffvhuff,ffwavesynth,fits,flac,flashsv,flashsv2,flic,flv,fmvc,fourxm,ftr,g723_1,g729,gdv,gem,gif,gremlin_dpcm,gsm,gsm_ms,gsm_ms_at,h261,h263,h263_v4l2m2m,h263i,h263p,hap,hca,hcom,hdr,hnm4_video,hq_hqa,hqx,huffyuv,hymt,iac,idcin,idf,iff_ilbm,ilbc,imc,indeo2,indeo3,indeo4,indeo5,interplay_acm,interplay_dpcm,interplay_video,ipu,jacosub,jpeg2000,jpegls,jv,kgv1,kmvc,lagarith,libaom,libaom_av1,libcodec2,libdav1d,libgsm,libgsm_ms,libilbc,libjxl,libopencore_amrnb,libopencore_amrwb,libopenh264,libopenjpeg,libopus,librsvg,libschroedinger,libspeex,libvorbis,libvpx_vp8,libvpx_vp9,libzvbi_teletext,loco,lscr,m101,mace3,mace6,mdec,media100,metasound,microdvd,mimic,misc4,mjpeg,mjpeg_qsv,mjpegb,mlp,mmvideo,motionpixels,mp1,mp1float,mp2,mp2float,mp3,mp3adu,mp3adufloat,mp3float,mp3on4,mp3on4float,mpc7,mpc8,mpeg1video,mpeg1_v4l2m2m,mpeg2video,mpeg2_qsv,mpeg2_v4l2m2m,mpeg4,mpeg4_v4l2m2m,mpegvideo,mpl2,msa1,mscc,msmpeg4v1,msmpeg4v2,msmpeg4v3,msnsiren,msp2,msrle,mss1,mss2,msvideo1,mszh,mts2,mv30,mvc1,mvc2,mvdv,mvha,mwsc,mxpeg,nellymoser,nuv,on2avc,opus,paf_audio,paf_video,pam,pbm,pcm_alaw,pcm_bluray,pcm_dvd,pcm_f16le,pcm_f24le,pcm_f32be,pcm_f32le,pcm_f64be,pcm_f64le,pcm_lxf,pcm_mulaw,pcm_s16be,pcm_s16be_planar,pcm_s16le,pcm_s16le_planar,pcm_s24be,pcm_s24daud,pcm_s24le,pcm_s24le_planar,pcm_s32be,pcm_s32le,pcm_s32le_planar,pcm_s64be,pcm_s64le,pcm_s8,pcm_s8_planar,pcm_sga,pcm_u16be,pcm_u16le,pcm_u24be,pcm_u24le,pcm_u32be,pcm_u32le,pcm_u8,pcm_vidc,pcx,pfm,pgm,pgmyuv,pgssub,pgx,phm,photocd,pictor,pjs,png,ppm,prosumer,psd,ptx,qcelp,qdm2,qdmc,qdraw,qoi,qpeg,qtrle,r10k,r210,ra_144,ra_288,rasc,rawvideo,realtext,rka,rl2,roq,roq_dpcm,rpza,rscc,rv10,rv20,s302m,sami,sanm,sbc,screenpresso,sdx2_dpcm,sgi,sgirle,shorten,simbiosis_imx,sipr,siren,smackaud,smacker,smc,smvjpeg,snow,sol_dpcm,sonic,sp5x,speedhq,speex,srgc,srt,ssa,stl,subrip,subviewer,subviewer1,sunrast,svq1,svq3,tak,targa,targa_y216,tdsc,text,theora,thp,tiertexseqvideo,tiff,tmv,truehd,truemotion1,truemotion2,truemotion2rt,truespeech,tscc,tscc2,tta,twinvq,txd,ulti,utvideo,v210,v210x,v308,v408,v410,vb,vble,vcr1,vmdaudio,vmdvideo,vmnc,vnull,vorbis,vp3,vp4,vp5,vp6,vp6a,vp6f,vp7,vp8,vp8_qsv,vp8_v4l2m2m,vp9,vp9_qsv,vp9_v4l2m2m,vplayer,vqa,vqc,wady_dpcm,wavarc,wavpack,wbmp,wcmv,webp,webvtt,wmav1,wmav2,wmavoice,wmv1,wmv2,wnv1,wrapped_avframe,ws_snd1,xan_dpcm,xan_wc3,xan_wc4,xbin,xbm,xface,xl,xpm,xsub,xwd,y41p,ylc,yop,yuv4,zero12v,zerocodec,zlib,zmbv,’
WARNING: library configuration mismatch
avcodec configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --docdir=/usr/share/doc/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags=‘-O2 -flto=auto -ffat-lto-objects -fexceptions -g -grecord-gcc-switches -pipe -Wall -Wno-complain-wrong-lang -Werror=format-security -Wp,-U_FORTIFY_SOURCE,-D_FORTIFY_SOURCE=3 -Wp,-D_GLIBCXX_ASSERTIONS -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -fstack-protector-strong -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -m64 -mtune=generic -fasynchronous-unwind-tables -fstack-clash-protection -fcf-protection -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer’ --extra-ldflags=‘-Wl,-z,relro -Wl,–as-needed -Wl,-z,now -specs=/usr/lib/rpm/redhat/redhat-hardened-ld -specs=/usr/lib/rpm/redhat/redhat-annobin-cc1 -Wl,–build-id=sha1 ’ --extra-cflags=’ -I/usr/include/rav1e’ --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-version3 --enable-bzlib --enable-chromaprint --disable-crystalhd --enable-fontconfig --enable-frei0r --enable-gcrypt --enable-gnutls --enable-ladspa --enable-libaom --enable-libdav1d --enable-libass --enable-libbluray --enable-libbs2b --enable-libcodec2 --enable-libcdio --enable-libdrm --enable-libjack --enable-libjxl --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libilbc --enable-libmp3lame --enable-libmysofa --enable-nvenc --enable-openal --enable-opencl --enable-opengl --enable-libopenh264 --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-libplacebo --enable-librsvg --enable-librav1e --enable-librubberband --enable-libsmbclient --enable-version3 --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtesseract --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libv4l2 --enable-libvidstab --enable-libvmaf --enable-version3 --enable-vapoursynth --enable-libvpx --enable-vulkan --enable-libshaderc --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libxml2 --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-avfilter --enable-libmodplug --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-lto --enable-libvpl --enable-runtime-cpudetect
libavutil 58. 29.100 / 58. 29.100
libavcodec 60. 31.102 / 60. 31.102
libavformat 60. 16.100 / 60. 16.100
libavdevice 60. 3.100 / 60. 3.100
libavfilter 9. 12.100 / 9. 12.100
libswscale 7. 5.100 / 7. 5.100
libswresample 4. 12.100 / 4. 12.100
libpostproc 57. 3.100 / 57. 3.100
Input #0, flac, from ‘1-01 Lucifer.flac’:
Metadata:
MUSICBRAINZ_RELEASEGROUPID: 5e8f11c2-e08c-3e36-a3e6-d6954b1bf88f
ORIGINALYEAR : 1979
RELEASETYPE : album
MUSICBRAINZ_ALBUMID: b0045ceb-3536-3a5d-91a7-e0919c4e0024
PERFORMER : Andrew Powell (chorus master);Ian Bairnson (acoustic guitar and electric guitar);BJ Cole (steel guitar);Stuart Elliott (drums (drum set) and percussion);Duncan Mackay (keyboard);Eric Woolfson (keyboard);Alan Parsons (additional);Eric Woolfson (additional)
CONDUCTOR : Andrew Powell
ENGINEER : Patrick Jauneaud;Dave Siddle;Alan Parsons
PRODUCER : Test
ASIN : B000002VCB
DATE : 1990-10
LABEL : Arista
RELEASECOUNTRY : US
ALBUM : Eve
MUSICBRAINZ_ALBUMARTISTID: f98711e5-06f7-43ed-8239-da0f61a9c460
album_artist : The Alan Parsons Project
SCRIPT : Latn
TOTALDISCS : 1
disc : 1
MEDIA : CD
TOTALTRACKS : 9
MUSICBRAINZ_TRACKID: 630595da-fe96-4e7f-8b65-904c078e25f9
TITLE : Lucifer
MUSICBRAINZ_ARTISTID: f98711e5-06f7-43ed-8239-da0f61a9c460
ARTIST : The Alan Parsons Project
MUSICBRAINZ_WORKID: d1fdd296-f032-36c3-ba12-1b0a041d7e04
LANGUAGE : zxx
WORK : Lucifer
COMPOSER : Test
COMPOSERSORT : Test
ISRC : USAR19700011
MUSICBRAINZ_RELEASETRACKID: 67122fcc-44ce-3718-a729-77b56a3f3c1e
track : 1
GENRE : Pop;Pop Rock;Progressive Rock;Rock
REPLAYGAIN_TRACK_PEAK: 1.000000
REPLAYGAIN_ALBUM_GAIN: -7.20 dB
REPLAYGAIN_ALBUM_PEAK: 1.000000
REPLAYGAIN_TRACK_GAIN: -7.17 dB
WRITER : Test
TRACKTOTAL : 9
DISCTOTAL : 1
Duration: 00:05:08.52, start: 0.000000, bitrate: 941 kb/s
Stream #0:0: Audio: flac, 44100 Hz, stereo, s16
Side data:
replaygain: track gain - -7.170000, track peak - 0.000023, album gain - -7.200000, album peak - 0.000023,
Stream #0:1: Video: mjpeg (Baseline), yuvj420p(pc, bt470bg/unknown/unknown), 1200x1183 [SAR 1:1 DAR 1200:1183], 90k tbr, 90k tbn (attached pic)
Metadata:
comment : Cover (front)
In plex, the album has the Artist listed as “Eric Woolfson & Alan Parsons” and the track has a blank value for Artist.
Can someone please help me understand where these tags are coming from in Plex?
If the album artist and the track artist are identical, then clients do usually omit them track artist from showing on album pages.
When was this checked? After the album has been scanned into Plex or before?
Make sure you have a folder structure as shown in this article: https://support.plex.tv/articles/200265296-adding-music-media-from-folders/
Are there other albums by that particular artist?
If this is the only album, perform the Plex Dance “light” with this album.
(“light” meaning you can omit step 4)
  1. Good to know, thanks!
  2. After. Though I did perform the light plex dance on this album and it did not fix the issue. I also performed a light plex dance on the entire artist, this did not work either. My folder structure is Music/AlbumArtistName/YYYY - AlbumName/TrackNumber - TrackName.ext. I know this isn’t exactly what is specified, but I think it’s close enough, right?
  3. All of the albums I have from The Alan Parsons Project have this issue.
I just created a new library, using the same settings, that just contains the folder “Music/The Alan Parson Project/”. All the albums in this library have the correct album artist value of “The Alan Parsons Project”
Then perform the Plex Dance with all of them at the same time. Ensure that not a single track among them has the wrong album artist info tagged.
Perfectly fine. But ensure that all of the albums inside of a certain AlbumArtist folder have identical content in their AlbumArtist tags.
This did not work, when performed exactly as prescribed. More on that later.
I did confirm that they all have the same value in the tags.
I found the solution, the light plex dance, but with a caveat.
I also have the album “Freudiana” by “Eric Woolfson & Alan Parsons”. When I removed the directories “Music/The Alan Parsons Project/” and “Music/Eric Woolfson & Alan Parsons/” for the light plex dance, the tags were fixed when the directories were added back.
Unfortunately, this method removed my ratings for the tracks on “Eve”. I will manually rerate those tracks.
Thank you for your help!
