Plex is not using my local movie background / fanarts
Server Version# : 1.25.1.5286
As you can see on the screenshot (plex web + plex server on my Synology nas), I have the movie displayed correctly in my library.
The issue is that the background image is not being used… Based on the doc, the “fanart.jpg” image should be used for the background, but it isn’t …
The only way to get a background image is to click on the pen icon, and load a background manually… (can’t be a solution with my huge library)
Am I missing something ? What can I do for having Plex using my local images ?
Furthermore, when using the “PEN ICON > Wallpaper + selecting a wallpaper” to finally change the background, the background image is not being saved to my movie folder ! Where’s that image stored then ?
Here’s the “Movies” library config and setup if it helps:
